When bringing in a 2013 model into 2014, the storboards captions are jumbled together and the trunks of the palm trees on the roadway are not there. I have Show Backfaces toggled on...
Solved by Henrik-B. Go to Solution.
The problem of the transparent trees for some styles should be fixed in later versions. For 2014, it can be fixed by replacing a single style texture in the resource folder.
If you tell me the name of the style for which you have this issue, I can find out the corresponding texture and send you a fixed version. (we have different palm tree styles - so I couldn't easily see it from the image).
To find out the style, you can select the tree and check the style name in the Properties explorer.
This is the road style, Boulevard with Palms. I posted in another thread that this is just exclusive to Infraworks 2014. It really doesn't have anything to do with opening up a 2013 database in 2014. We have tested this on several machines and can reproduce this issue with no effort. Seems to be the first bug.
Here is a workround that should fix the transparent trunk for you:
1. In Windows explorer, find your infraworks resource folder. The path is usually something like this:
C:\ProgramData\Autodesk\InfraWorks 2014\Resources
Note that ProgramData is a system folder that is often hidden by default, so that you might not see ProgramData in c:.
2. Inside the resource folder, the texture file that causes the problem in your case is in this subfolder:
<Your_ResourceFolder>\assets\3DSMaxContent\Trees\PalmTree007_Var01
3. Replace this file by the one I attached here.
This should fix the California Palm tree model - which is the road decoration of your road style.
Just as a background information - particularly useful if you get this issue with other (or own) models: The problem here is that the models contain some monochrome jpg textures that are not handled correctly by AIW 2014. The attached file is another version of the same image, but converted to color-rgb. I obtained it by opening the jpg in IrfanView, choosing "Increase Color Depth" in the image menu, and overwriting the texture file with the converted one.
Please let me know if it helped or if anything is unclear.
That worked great. Now, what is the difference in the .jpg that you attached opposed to the one that was already in the folder?
Great to hear. The difference is that the new image is an rgb jpg image - while the old one was monochrome jpg. This works around the bug in 2014 and bring the texture in correctly.
Thanks for reporting that it helped. If you like to know how to recognize and repair monochrome jpgs - this is easily possible using the free tool irfanview:
When opening the original version of the texture, you would see in the status bar something like "512 x 2048 x 8 BPP". The 8 BPP indicates that it is monochrome.
If you choose Image->IncreaseColorDepth, and then "24 BPP", it will change to "512 x 2048 x 24 BPP". Then, you just have to save as jpg again to have a converted version that works fine in 2014.
Nice!! This is great info. Would you mind if I blogged about this?
You are welcome - feel free to blog about it.
In case you see other models with this issue: One problem is that it is sometimes hard to find out which texture file caused the actual problem. If you cannot find it for any of our shipped models, feel free to ask me I and I will find out.
One other case I already know of is this one:
This texture has the same issue and is not just used for tree016_var05 style, but also for some others. So, replacing it by the one attached here will fix a few other tree variants at once.
That is the other one that I was actually referring to. Thanks again.
Here you go...
http://civil3dj.wordpress.com/2013/04/12/infraworks-2014-bug-resolved/
Thanks again!!
Thank you, too, for posting it in the blog. Since it's quite likely for most users to encounter this problem in 2014 sooner or later, it's good that more people know about it.
I found another material that needed to be updated. It's C:\ProgramData\Autodesk\InfraWorks 2014\Resources\assets\shared_textures\Protein\Roof_Materials\Thermal - Moisture.Roofing - Siding Panels.Metal Ribbed.Copper.bump.jpg
