• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Member
    problem installing impression 3
    797 Views, 2 Replies
    04-01-2010 01:28 PM
    hello evryone,
    i came a cross with a problem during installing the impression 3,
    i'm wondering if you could help me please.
    the problem is -
    i'm starting the installation and after a few minutes i'm getting a massage of fatal error.
    i have win 7 64 bit
    i searched the net for similar problem but i didn't found not the problem nor a solution.
    thank you all for your help.
    Please use plain text.
    Valued Contributor
    Jim_Earle
    Re: problem installing impression 3
    08-11-2010 11:34 AM in reply to: znina
    Try right clicking the install file and select 'run as administrator' and see if that helps. If not try re-downloading the install files
    Distinguished Contributor
    09-17-2010 04:22 PM in reply to: Jim_Earle
    What is the exact message?  What are your system specs?
