• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    New Member
    gabika.krausova
    impression doesn't import some of the blocks
    949 Views, 1 Replies
    01-15-2012 05:43 PM
    I'm using autoCAD 2009 and Autodesk Impression 3
    there is one constant problem I have. When I try to import a .dwg file into Impression, it sometimes simply don't import all the layers, usually it do not import some of the blocks but do import others, I really don't understand where could be a problem. And when I try to get those blocks by "update CAD geometry" a message pops out saying
    "Some of the associated DWG layers for the Impression layers you have selected are now set to be off, frozen, or turned off for plotting. Do you still want to refresh cad geometry from these layers?"
    But when I open the file in CAD, these layers are all on, non-frozen and not turned off for plotting either. I hope you can help me with that.
    Please use plain text.
    Active Contributor
    Re: impression doesn't import some of the blocks
    01-17-2012 02:30 PM in reply to: gabika.krausova
    can you post an example dwg file where you have this problem?
    I'll try to help.
    Cheers,
    Max V.
