• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Member
    Update CAD Geometry option greyed out
    588 Views, 1 Replies
    06-30-2010 05:11 AM
    I'm having a problem with the Update CAD Geometry option in Impresion 3. I've used this without fail previously but now if I change my CAD drawing and go to update the geometry, the option to update (all 3 options) are greyed ouit. Has anyone come across this before or know why this would happen?
    James
    Please use plain text.
    Valued Contributor
    Jim_Earle
    Re: Update CAD Geometry option grayed out
    08-11-2010 01:33 PM in reply to: jameswelch8411
    I have had this happen twice. Once when I had a blank impression file open and thought I was in the one I wanted. The other is when there was a problem with my impression file. Unfortunately I never found a fix for it. I had to start a new one and re-render it. I could however after that update the geometry with no problems, well aside the problems that feature has but I was able to do it.
    Have you tried starting a new impressions file and importing the cad file into it and then seeing if you get the same result?
