• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Member
    The file is invalid and cannot be imported (saving from 2011 / 2012)
    2014 Views, 6 Replies
    07-18-2011 02:23 PM
    Impression does not open files saved or exported from  autocad/architecture rel. 2011 and 2012,
    This is the error message "The file ".........." is invalid and cannot be imported
    someone has a trick?
    Hello everyone
    Please use plain text.
    New Member
    Re: The file is invalid and cannot be imported (saving from 2011 / 2012)
    08-30-2011 06:22 AM in reply to: davidetrovati.com
    Mine recently started doing the same thing.  When I try to import a dwg. from AutoCad Architecture 2012 it almost immediately thows up that error message saying "The file is invalid and cannot be imported".  I've installed the hotfix for Windows 7 and until about the last 2 or maybe 3 days it was working fine.  No problems.  I've even uninstalled and re-installed the program with no effect.  If there is some one out there that has some kind of a fix, I'd really like to find out about it.  Thanks.
    Valued Contributor
    TexShalter
    09-10-2011 06:54 AM in reply to: rpritchard
    Have you tried saving to an older version from autocad ?
    Member
    09-12-2011 01:01 AM in reply to: davidetrovati.com
    try to export the file for autocad (not A_architecture) may verify that there are objects with different colors from the pallet standard, the old 256 colors!,
    let me know.
    New Member
    06-22-2012 02:15 PM in reply to: davidetrovati.com
    I just came across this error and thread... I haven't expanded everything yet but the idea of the colors causing this seems to work. I have a file I saved down to 2007 and it still failed on the import.  However, I have a solid hatch in there that is true color... that may cause the problem?  I will have to explore.
    New Member
    08-30-2012 02:52 AM in reply to: sstefanc
    The problem is non-standard colours for line colours.
    We had a single polyline with a DIC colour. Once we deleted this one polyline, our CAD file imported just fine.
    Active Contributor
    gjcbachman
    02-20-2013 10:46 AM in reply to: Peter_Hughes
    I found this just in time.  Two of us spent almost 3 hours trying to figure out why a 2013 drawing saved back, stripped of everything and even dxf'd the file still wouldn't work.  After finding this post I found 3 layers set to true color, changed them and now it works.  Now hopefully we can come up with something that looks decent in the next hour.  Thanks!
    Lisa
    Windows 7 x 64
    AMD Phenom II X4 945 3.00 GHz
    16 GB RAM
    NVIDIA Quadro 2000
    Civil 3D 2013 (G.114.0.0, SP1)
