• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Distinguished Contributor
    Selecting and Moving Multiple Spline Control Points
    497 Views, 1 Replies
    12-15-2009 06:45 AM
    When I dig down through selection levels to the Spline Control Point level, how do I window to select multiple spline control points? Once I've made my selection of multiple points, how do I move all those points at once?
    DD
    Please use plain text.
    Re: Selecting and Moving Multiple Spline Control Points
    01-21-2010 01:57 PM in reply to: dbd63
    I'll bump this back up. This issue is really making me nuts. I have an object made up of several splines. I want to delete about half the splines. I can't select splines, though- my only selection modes are to select the entire object, or to click down a level where I can select individual control points. Why can't I select a level in between those two- individual splines? And not being able to select multiple control points at once makes the problem many times worse. The only way I've found to delete individual splines is to delete, one by one, each control point of the spline. This is nuts! Autodesk, if I've missed something, please tell me. If I haven't missed something, please fix this.
    DD
