• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Member
    Program crash with Impression 2
    1063 Views, 4 Replies
    04-19-2010 04:17 AM
    If I want to open each dwg file with impression 2 there every time the program crash. What can be the cause?
    Please help me!
    Please use plain text.
    Valued Contributor
    Jim_Earle
    Re: Program crash with Impression 2
    08-11-2010 11:32 AM in reply to: cadman1966
    seems like I remember a problem like this and the reason was not enough memory. Obviosuly if you have more than enoguh then its a differnt reason. If you can try it on another computer that would rule out a bad file. You may try re-installing impressions as well or give version 3 a shot.
    01-26-2011 01:10 PM in reply to: Jim_Earle
    Yikes, crashing on a system with 8gb ram here! Tried it on another with 12gb ram, same result. Trying version 3 now.
    Valued Contributor
    TexShalter
    02-03-2011 02:21 PM in reply to: c.leitch
    02-03-2011 02:42 PM in reply to: cadman1966
    Thank you so much, I had not seen the SP. FWIW working fine on version 3.
