• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Impression
    pak
    Active Member
    Re: Memory Error
    01-24-2007 05:58 PM in reply to: TerribleTim68
    Ah, not supporting 64 bit. This explains failure to launch. I have 64 bit Windows XP Professional. You'd think the 'system requirements tester' would have picked that up.
    Please use plain text.
    Active Contributor
    Re: Memory Error
    02-14-2007 02:43 PM in reply to: TerribleTim68
    We just posted Impression Technology Preview 4 this morning:
    http://labs.autodesk.com/Impressionlanding.html
    This version has some improvements that should reduce the out of memory conditions.
    We also save a recovery file if we need to close due to low memory conditions.
    Active Member
    Re: Memory Error
    03-05-2007 03:59 PM in reply to: TerribleTim68
    Using 4, I get this message quite a bit, usually with fills, blocks and printing.
    Active Contributor
    Re: Memory Error
    03-08-2007 10:34 AM in reply to: TerribleTim68
    using 4 and ran into this today also.
    any tips on how to avoid this error?
