• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Active Contributor
    Layers: composed of two or more sytles
    153 Views, 1 Replies
    08-10-2009 07:56 AM
    Is there a way to tell which layers are composed of a combination of styles?
    Inadvertantley when using the fill tool I will fill the same area with two different fill styles. But the layer description just shows the latest style.
    THanks,
    HC
    Please use plain text.
    Valued Contributor
    Re: Layers: composed of two or more sytles
    08-10-2009 09:18 AM in reply to: HC1975
    When you're set on the current layer there will be a little yellow triangle on the right hand side above the style pallette indicating style exceptions - more than one style applied to the layer. You also have the ability to select the style exceptions.
