Autodesk Impression
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Impression 3 and Autocad 2011
- Highlight
- Email to a Friend
My question is: ¿doesn't impression 3 work with autocad 2011?
I have downloaded autocad 2011 trial version and I don't see the "Export to Impression" option that there was in autocad 2010.
Help me, please.
Thanks.
Re: Impression 3 and Autocad 2011
- Highlight
- Email to a Friend
Just installed my new ACA 2011, i'm on subscription. So last year i had
installed Autodesk Impression 3 with ACA2010.
After installed it, i had a new function group available in my ribbon
"Export to Impression" and it works great with the ACA2010.
I would like to have the same function group working with my last 2011
version.
I have tried to import this function group through the customisation
interface possibility : not working, White and empty function group
I have tried to copy the AcImpression.cuix file from ACA2010 to ACA2011
support folder : not working, White and empty function group
Did you have the same problem of me (i'm on vista 64bit and a french version
of vista and ACA2011) ?
thank you for any solution.
JF Lemoing
Architect
France
- Highlight
- Email to a Friend
Same thing here.
AutoCAD2011+Impression3 won't work.
(Windows 7 32bit)
Old AutoCAD versions used to have a toolbar.
2010 version only had a button to send to Impression
2011 has zero option.
Another screwed-by-impression time!
Thank you Autodesk!
- Highlight
- Email to a Friend
I have Vista SP1.
Running AutoCAD Architecture 2011. Just opened the .dwg file in Impression 3. Worked fine.
- Highlight
- Email to a Friend
Indeed, there is no Ribbon tab any longer, but the two still work together. There is just no longer a direct to Impression shortcut.
- Highlight
- Email to a Friend
I've been trying to open drawings from ACAD 2011 in Impression 3 but keep getting error messages. Is there a patch for this???? I've spent some time learning to use Impression but now I can't use it. HELP.
- Highlight
- Email to a Friend
Here's a patch that might help. But it's for Windows 7. Check out this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
- Highlight
- Email to a Friend
I tried it but still have problems. Hope Autodesk comes up with a solution. Anyone have a good substitute software program?
- Highlight
- Email to a Friend
Have you tried removing Impression from the computer and reinstalling it. It could be a bad install. You can do this through the control panel (remove) and then reinstall it with your virus protection off, and then run the hotfix.
- Highlight
- Email to a Friend
The closest program I have seen is called Piranesi. It looks pretty good but is $$$.
