• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Active Member
    Impression 3 and Autocad 2011
    3549 Views, 10 Replies
    04-04-2010 07:02 AM
    Hi, I'm a spanish student, so my english language isn't very good, sorry.
    My question is: ¿doesn't impression 3 work with autocad 2011?
    I have downloaded autocad 2011 trial version and I don't see the "Export to Impression" option that there was in autocad 2010.
    Help me, please.
    Thanks.
    Please use plain text.
    *jf lemoing - Architecte DPLG
    Re: Impression 3 and Autocad 2011
    04-15-2010 02:01 PM in reply to: javiergarciaperez
    Hi all,
    Just installed my new ACA 2011, i'm on subscription. So last year i had
    installed Autodesk Impression 3 with ACA2010.
    After installed it, i had a new function group available in my ribbon
    "Export to Impression" and it works great with the ACA2010.
    I would like to have the same function group working with my last 2011
    version.
    I have tried to import this function group through the customisation
    interface possibility : not working, White and empty function group
    I have tried to copy the AcImpression.cuix file from ACA2010 to ACA2011
    support folder : not working, White and empty function group
    Did you have the same problem of me (i'm on vista 64bit and a french version
    of vista and ACA2011) ?
    thank you for any solution.
    JF Lemoing
    Architect
    France
    New Member
    screwedbyimpression
    08-24-2010 07:08 AM in reply to: *jf lemoing - Architecte DPLG
    Same thing here.
    AutoCAD2011+Impression3 won't work.
    (Windows 7 32bit)
    Old AutoCAD versions used to have a toolbar.
    2010 version only had a button to send to Impression
    2011 has zero option.
    Another screwed-by-impression time!
    Thank you Autodesk!
    Active Contributor
    09-10-2010 09:41 AM in reply to: javiergarciaperez
    I have Vista SP1.
    Running AutoCAD Architecture 2011.  Just opened the .dwg file in Impression 3.  Worked fine.
    Distinguished Contributor
    09-17-2010 04:16 PM in reply to: javiergarciaperez
    Indeed, there is no Ribbon tab any longer, but the two still work together.  There is just no longer a direct to Impression shortcut.
    Active Member
    sylvialyons
    07-14-2011 05:12 PM in reply to: nvanlaar
    I've been trying to open drawings from ACAD 2011 in Impression 3 but keep getting error messages. Is there a patch for this???? I've spent some time learning to use Impression but now I can't use it. HELP.
    Active Contributor
    07-15-2011 07:07 AM in reply to: sylvialyons
    Here's a patch that might help.  But it's for Windows 7.  Check out this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14719247&linkID=9364941
    Active Member
    sylvialyons
    07-18-2011 01:01 PM in reply to: spilon
    I tried it but still have problems. Hope Autodesk comes up with a solution. Anyone have a good substitute software program?
    Active Contributor
    07-18-2011 02:28 PM in reply to: sylvialyons
    Have you tried removing Impression from the computer and reinstalling it.  It could be a bad install.  You can do this through the control panel (remove) and then reinstall it with your virus protection off, and then run the hotfix.
    07-18-2011 02:46 PM in reply to: sylvialyons
    The closest program I have seen is called Piranesi.  It looks pretty good but is $$$.
