• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Member
    st10000226
    Importing problem from CAD
    1094 Views, 1 Replies
    09-21-2011 06:46 AM
    I installed the hotfix files.
    However, when I try to import Autocad files, although the file don't crash anymore, but the layers comes all missed up as in the capture screen attached. I tried to import each layer on its own and still the same problem.
    Any advice?
    Please use plain text.
    Active Contributor
    Re: Importing problem from CAD
    10-19-2011 12:08 PM in reply to: st10000226
    Have you solved this problem yet?
    If not, try setting up a layout with a viewport and select those options while you import it.
    Let us know how it works.
    Cheers,
