• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression
    Active Contributor
    Here is the Windows 7 hotfix for Impression 3
    3204 Views, 12 Replies
    02-08-2012 07:48 AM
    For those that have trouble finding it. (Info below)
    Greets!
    Max.
    (From Autodesk website):
    This hotfix corrects a problem with Autodesk® Impression 3 on Microsoft® Windows®7 where attempting to open, save or import a drawing will cause Autodesk Impression 3 to fail.
    Note: This hotfix addresses the known issue above, but does not provide full support for Impression 3 on Windows 7.
    Installation Instructions
    You must have administrative privileges on your Microsoft Windows operating system to complete this installation process.
    1. Close Autodesk Impression 3.
    2. Navigate to the Api folder. For example, C:\Program Files\Autodesk Impression 3\Api\.
    3. In this folder, find the UILib.dll file and rename it UILib.bak.
    4. In this folder, find the CustomControls.dll file and rename it CustomControls.bak.
    5. Download and copy the updated UILib.dll and CustomControls.dll file to the Api folder.
    6. Restart Autodesk Impression 3.
    Please use plain text.
    Re: Here is the Windows 7 hotfix for Impression 3
    03-12-2012 09:10 AM in reply to: makovich
    this hot fix keeps Impression from crashing while trying to perform open or import, but you still cant open or import. the functions dont work.
    (win 7-64bit)
    Active Contributor
    03-12-2012 09:37 AM in reply to: makovich
    Here is a known bug that may be causing your trouble:
    "One issue that makes Impression crash is if any of your imported CAD layers are not in Index Colours. If they are True Colours then this has a massive impact."
    I suggest that in order to overcome some issues, try saving your drawing in an older format, let's say Autocad 2004 for example, and see if the older format file still has the issues.
    Let us know if the above helps.
    Max.
    03-12-2012 11:07 AM in reply to: makovich
    tried saving in older formats (and dxf and dwf), didnt chnage anything.  The colors are set for the basic 8. still doesnt import.
    Could it be possible that the file I am trying to import in to, was originally an Impression 2 file? Would that effect it?
    Active Contributor
    03-12-2012 12:38 PM in reply to: artisteroi
    Mmmm.... have you tried importing the CAD file into a blank new Impression file?
    If that works, maybe you can save it as an Impression file, and afterwards, try to merge both Impression files.
    Ah, and save the Impression 2 file with Impression 3, then close it and reopen it.
    I hope this helps.
    Max.
    03-13-2012 06:03 AM in reply to: makovich
    tried all that. nothing works. :smileysad: thanks for the suggestions though. I have decioded to use my old backup pc which has XP64 on it. It all seems to be working fine on that box.
    I dont think there is anything wrong with the files. I just think the import and open functions are not compatiblew with windows 7
    03-13-2012 11:48 AM in reply to: artisteroi
    Dimensions. the dims cant be imported. either remove dims or explode dims. It will import fine after that. Verified
    Active Contributor
    03-15-2012 08:47 AM in reply to: makovich
    Sadly, a lot of people report problems with W7
    I hope that Autodesk addresses this problem soon, but I do not have high hopes of this happening since it seems they are sort of leaving this program hanging in limbo.
    Max.
    03-15-2012 09:21 AM in reply to: makovich
    impression has been dropped. 3 is the last version. :smileysad: the problem is unlikly to be rectified. ever.
    Active Contributor
    03-16-2012 04:50 PM in reply to: makovich
    Has there been an official announcement in this regard?
    I know support has been ostensibly dropped, but I have been asking if Impression has been officially discontinued but nobody wants to admit that (yet).
    Max.
