• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Impression Wishes
    Distinguished Contributor
    Reference Impression drawing in to AutoCAD
    1713 Views, 4 Replies
    05-16-2009 08:48 PM
    This isn't really for Impression but for AutoCAD.
    I would like to be able to reference an Impression file in AutoCAD.
    Why? I created an autocad drawing, then ran some Impression styles on it. Now I would like to import that back to my sheetset as a new figure. In this case I just wanted a title border around my new artisitcly attractive image that I created in Impression. I realize I could pull in the border in to impressions but I would like to have the sheet set still in control of that title border.
    Please use plain text.
    Valued Contributor
    Re: Reference Impression drawing in to AutoCAD
    06-18-2009 08:32 AM in reply to: estiles
    What about saving the impression rendering as a jpeg that could be xrefed into your drawing set? Each time you update the impression rendering jpeg, that could update the xrefed rendering in your set.
    06-18-2009 04:10 PM in reply to: estiles
    I guess it is pretty easy to make a JPG file. Thanks for the reply.
    Active Contributor
    08-10-2009 06:41 AM in reply to: estiles
    only difficulty i could see would be the jpeg file would have to be rotated & moved to align with the original CAD linework. Also the entire square canvas from Impression would be referenced; which may obscure the CAD linework surrounding the image area.
    Valued Contributor
    08-10-2009 09:11 AM in reply to: estiles
    Remember you can image clip the image to cut down the size once alligned. You can also use draw order to send the image back underneath the linework.
