• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Green Building Studio - Web-Based Service
    Member
    adrianna.slusarenko
    Too much floor and ceiling area error...
    1711 Views, 3 Replies
    09-09-2010 12:45 PM
    Problems were encountered with the building information model you sent to Green Building Studio.  See below for details.
    1. There is too much floor and ceiling area in the gbXML file received by Green Building Studio:
      • Floor and ceiling area = 2,928 m2
      • Building area = 2,365 m2
      The floor and ceiling area must be within 20% of the building area to perform meaningful energy analysis.
      Note: Typically this problem occurs when room or space objects are not properly defined in your Revit model. Check that all interior volumes in your model contain room or space objects that are fully enclosed by floors, walls, roofs or other room bounding elements. See Using Green Building Studio with Revit Architecture and Revit MEP for helpful details on room and space objects. To inspect the analytical model of the gbXML file in Revit 2010, click Export > gbXML on the Revit application menu and explore the details tab.
    2. Construction id=ASHIF5 could cause simulation failures.
    Has anyone seen this and/or know how to fix it?
    Thank you,
    Adrianna
    Please use plain text.
    Employee
    Re: Too much floor and ceiling area error...
    10-08-2010 10:05 AM in reply to: adrianna.slusarenko
    Hi
    Have you tried following the tips in the error message? Check that all interior volumes in your model contain room or space objects that are fully enclosed by floors, walls, roofs or other room bounding elements. To inspect the analytical model of the gbXML file in Revit, click Export > gbXML on the Revit application menu and explore the details tab.
    Best Regards,
    Marjorie Stein
    Marjorie Stein
    Product Manager
    Autodesk, Inc.
    Member
    adrianna.slusarenko
    10-11-2010 06:50 AM in reply to: adrianna.slusarenko
    Yes, I have redone it several times, and it still says that there is too much floor and ceiling area...
    Employee
    11-12-2010 07:50 AM in reply to: adrianna.slusarenko
    Is it possible that you provide your RVT or gbxml file so that we can analyze this?
