• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Green Building Studio - Web-Based Service
    New Member
    Revit to GBXML
    878 Views, 2 Replies
    06-22-2012 07:11 AM
    Hi all,
    The revit geometry is exported as gbxml format and in the export gbXML –settings, all the external walls are showing as internal walls. This is causing the external walls not to show up in the energy modeling software later when imported. Is there a easier way to fix this issue ? Any insight in this area is much appreciated.
    Harshana
    Please use plain text.
    Employee
    Re: Revit to GBXML
    06-24-2012 08:58 PM in reply to: hthimmanna
    This may be a result of that the Function parameter on the wall type is set to “Interior”. Can you please check that?
    For more info please see: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2171-Print_Ex2171...
    Anna Oscarson
    QA Analyst
    Building Design and Collaboration, IPG
    New Member
    Re: Revit to GBXML
    07-10-2012 11:51 AM in reply to: AnnaOscarson
    Thanks Anna.. That worked
    Harshana
