• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Green Building Studio - Web-Based Service
    Failed Run DOE 2.2 Error
    1313 Views, 3 Replies
    10-26-2010 01:05 PM
    I am getting the following error
    Issue: An error has occurred related to the DOE-2 simulation. It is below and may be of assistance in determining the issue with your building model. If it is unclear what the issue is, please submit the issue at the link below and include the gbXML file used for this run. <br/> *16482* Y = -3563.6142339895<br/>*ERROR***************************** ================ *****************************************<br/>*ERROR*****VALUE NOT BETWEEN -2000.0000 AND 2000.0000<br/> *16551* Y = -4380.8191930118<br/>*ERROR***************************** ================ *****************************************<br/>*ERROR*****VALUE NOT BETWEEN -2000.0000 AND 2000.0000<br/> *16564* Y = -4377.3191930118<br/>*ERROR***************************** ================ *****************************************<br/>*ERROR*****VALUE NOT BETWEEN -2000.0000 AND 2000.0000<br/> *16577* Y = -4377.3191930118<br/>*ERROR***************
    How do I find the elements this is refering to? I thought hte numbers would be the Revit ID but does not appear to be the case.  Checked the file thourghly and found no errors that I know of.  Any Ideas?
    Please use plain text.
    Employee
    Re: Failed Run DOE 2.2 Error
    11-12-2010 07:56 AM in reply to: chubbard
    You can open up your input gbxml file and look for the relevant unique text or number. Ex, you can look for '4380' in the gbxml file. There is a free tool called xmlnotepad. It works great with gbxml file for trouble shooting issue like this.
    11-12-2010 08:03 AM in reply to: chubbard
    I tried that in notepad, built a DB in Excel and Access. Just tried the xml notepad. None of them found any of the values listed in the error statement.  I suspect these are being misread by the DOE application, but I do not know why.
    How does one get support for GBS from ADESK beside asking questions on the discussion boards?
    Employee
    11-16-2010 07:57 PM in reply to: chubbard
    You can send email to support.gbs@autodesk.com with your input model file. We can further investigate this issue.
