• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk GIS Design Server
    Member
    Trouble with Design FastView
    98 Views, 3 Replies
    09-16-2002 06:46 PM
    I'm trying to use Design FastView with Win 2k and Java version 1.3.1_04 but when I run "cachemgr refresh" an error occurs.
    Database tables for FastView are created, and themes are also configured.
    Here a short listing of the output :
    /*** snip ******************
    D:\GIS_Design_Server\Cache>java -ms8m -mx64m -cp ";E:\PROGRA~1\Autodesk\GISDES~2/java/lib/cachemgr.jar;E:\PROGRA~1\Autodesk\GISDES~2/java/lib/classes12.zip" com.shl.gis.cachemgr.cachemgr refresh
    Copyright (c) 2002, Autodesk, Inc. All rights reserved.
    Enter password for Oracle user dom3:
    Enter password for Vision* user agds:
    Builder "Builder0" added
    Builder0 Started processing transaction 31 at: Tue Sep 17 11:00:17 CEST 2002
    failed to send data
    error making directory D:/GIS_Design_Server/Cache/new_theme
    failed to send data
    failed to send data
    failed to send data
    rnto failed
    rnfr failed
    rnfr failed
    rnto failed
    rnfr failed
    rnfr failed
    Builder0 Completed processing transaction 31 at: Tue Sep 17 11:01:04 CEST 2002 in: 47.438 seconds
    The directory is created but the nac files are empty
    It's strange I can run "sync" with no error also the defined
    port is up. If I trying to get an connection via Client Components, I can see the existing themes in debug mode and set one or more active but at the time of the "ConnectCacheMgrServer" command Map exits without any error messeges.
    Any ideas ? I hope so.
    Thanks in advance
    Thomas
    Please use plain text.
    Member
    Re: Trouble with Design FastView
    09-23-2002 05:19 PM in reply to: tluxa
    the generation problem is solved, it was an ftp problem with the root directory, but I still get no graphic output in map.
    The ftp connection is established and the .bits file
    is transfered to the client, but when map try to read any
    tile file I get an error message.
    Map try to read in d:/cache//new_theme/ and I don't have
    any idea for what reason this double slash appears.
    I run on Win NT,
    mFileserv.LocalDirectory = "D:/cache"
    theme.Name = "new_theme"
    Thanks in advance
    Thomas
    *Mena, Antoni
    Re:
    10-02-2002 11:56 PM in reply to: tluxa
        We have found the same problem
    than you.
        We are working on W2k (both
    client and server), and the symptom is the same: a double slash ("//") that
    appears inside the location string, so the .bits file is not found.
        The messages that we are getting
    through Info event for AeCmClient class are:
    INFO:
    class=642224914-03102002>m
    CacheMgr::Info
    class=642224914-03102002>"
    Connecting to ftp server kodiak
    INFO:
    CacheMgr::Info
    FTP connection established
    INFO:
    CacheMgr::Info
    Attempt to ftp tile: theme.bits
    INFO:
    CacheMgr::Info
    Reading tiff bitmap:
    c:/proyectos/cache//ATMT/theme.bits
    size=2>
    face=Arial>    "c:/proyectos/cache" i
    class=642224914-03102002>s the value for
    mCacheMgr.LocalDirectory.
    class=642224914-03102002>    "ATMT" is for
    mTheme.ThemeName.
        We have tried with "/" and "\",
    and the error is the same.
        Has anybody already solved this problem?
        Thank-you,
    Antoni Mena.
    Member
    Re:
    11-11-2002 08:19 AM in reply to: tluxa
    Just in case you have yet solved this problem, you may try to configure your W2K FTP service to use UNIX style directory listings...
    Hope it helps...
    Fabio
