• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk GIS Design Server
    *Mena, Antoni
    SQL error while trying to enable LTC cartridge tables
    118 Views, 1 Replies
    07-24-2002 07:02 PM
    Hi all,
    We have just installed GIS Design Server upon Windows 2000 and ORACLE 8.1.7.
    Everything seems to be working apart of version management.
    While trying to setting up the LTC following the "Administration Guide", we
    have got an error.
    In chapter 4 of the documentation, we are asked to run the following
    sentence in order to enable LT in the user tables:
    c$vis_se_1.dc.open_database('GENAPPDB','agds');
    This command returns an error (in Spanish), depending on the user that is
    running the command:
    1) if the user is the AGDS database owner (database "GENAPPDB", user
    "GENAPPDB") then the error is:
    ERROR en línea 1:
    ORA-20000: the user APadilla does not have the right capability class to
    connect to the database GENAPPDB
    ORA-06512: en "C$VIS_SE_A.DC_SESS", línea 364
    ORA-06512: en "C$VIS_SE_A.DC", línea 435
    ORA-06512: en "C$VIS_SE_A.DC", línea 425
    ORA-06512: en "C$VIS_SE_1.DC", línea 51
    ORA-06512: en línea 1
    We must clarify that "APadilla" is the user name in Windows 2000; this is
    not a user name neither in ORACLE nor in AGDS.
    2) if the user is an ORACLE administrator, then the error is:
    ERROR en línea 1:
    ORA-01422: la búsqueda exacta devuelve un número mayor de filas que el
    solicitado
    An approximation to the error message in english would be: "The exact search
    returns a greater number of rows than the demanded".
    What is happening?
    How can we avoid this error?
    Thank-you,
    Antoni Mena
    SYSIGSA
    mailto:amena@sysigsa.com
    Please use plain text.
    *Wasgarey, Jalal
    Re: SQL error while trying to enable LTC cartridge tables
    07-25-2002 06:16 PM in reply to: *Mena, Antoni
    Antoni,
    1) The problem may be because "APadilla" is not a user name in either Oracle
    or AGDS. You must ensure that "APadilla" has Administrator rights set. Check
    the following:-
    Control Panel > Administrative Tools > Computer Management> System Tools>
    Local Users and Groups > Groups > Administrators.
    "APadilla" must be listed in this group.
    2) From the Data Cartridge guide :
    To Cartridge Enable a Table
    1. Using SQL*Plus, connect to Oracle as the admin user for which you have
    EXECUTE privileges on the administration package or as the c$vis_sp_1 user.
    2. To create the view of the table, the constraints, and integrity triggers
    required by
    LTC, run c$vis_sp_1.admin.sp_alter_table() for a specific primary or
    indirect table.
    For example:
    sqlplus my_admin_account/my_password;
    BEGIN
    c$vis_se_1.DC.open_database('vis_db_name', 'vis_db_password');
    c$vis_sp_1.admin.sp_alter_table('DEPT', 'DEPT_V');
    c$vis_se_1.DC.close_database;
    END;
    It is necessary to "open" the GIS Design Server database before calling
    sp_alter_table.
    If you have any further problems, then I suggest you log a support call.
    Kind Regards
    Jalal
    ___________________________________
    Jalal Wasgarey
    GIS/Enterprise Product Support Technician,EMEA
    WW Support & Services,Autodesk
    Email: support.emea@autodesk.com
    "Antoni Mena" wrote in message
    news:A23CDA75444F9CE3199C31DD04317322@in.WebX.maYIadrTaRb...
    > Hi all,
    8.1.7.
    we
    > have got an error.
    > ERROR en línea 1:
    to
    > ERROR en línea 1:
    > solicitado
    search
    > What is happening?
    > Thank-you,
    > Antoni Mena
    > SYSIGSA
