Autodesk GIS Design Server
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Problems with the installati on of AGDS in the License
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
119 Views, 0 Replies
06-01-2004 05:26 AM
Autodesk GIS Design Server Installation Log File
________________________________________________
Install Date: 6-1-2004
08:23:53: SYSTEM: Total system memory is 244460Kb and available memory is 1048576Kb.
08:23:53: LIC: Variable ComputerNAme = SERV-GIS
08:23:53: LIC: Variable adskflex_LICENSE_FILE not found.
08:23:53: LIC: Variable adskflex_LICENSE_FILE = @SERV-GIS
08:24:12: The Product license file as entered: C:\Archivos de programa\Autodesk\Autodesk License Manager\License
08:24:12: The Product license file converted to DOS version: C:\ARCHIV~1\Autodesk\AUTODE~1\License
08:24:12: The Product license file used to install flexlm: C:\ARCHIV~1\Autodesk\AUTODE~1\License
08:24:29: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat sqlconnect.pl
TWO_TASK = BDMEGA Sys Password = SYS System Password = MANAGER
C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl :
################### Script started Tue Jun 1 08:24:30 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl : Oracle_Home env C:\oracle\ora81
C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl : C:\CD_AUT~1\GIS_DE~1\install\scripts\sql\sql_ver.s ql
C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl : This sql is version 801070000
C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl : This oracle is version 801070000
C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl : Successful oracle connection
C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl : Script finished with known exit condition Tue Jun 1 08:24:36 2004
08:24:39: Get sqlconnect.pl return code: 25
08:24:39: SQLCONNECT.PL - Successfull.
08:24:39: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat oracleversion.pl
TWO_TASK = BDMEGA System Password = MANAGER SRC Path = C:\CD_AUT~1\GIS_DE~1
C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion .pl:
################### Script started Tue Jun 1 08:24:39 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion .pl: Oracle_Home env C:\oracle\ora81
C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion .pl: Current oracle version 801070000
meets requirement of 801070000
C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion .pl: Script finished with known exit condition Tue Jun 1 08:24:40 2004
08:24:44: Get oracleversion.pl return code: 25
08:24:44: ORACLEVERSION.PL - Successfull.
08:24:44: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat vrfyinitora.pl
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l:
################### Script started Tue Jun 1 08:24:44 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: Oracle_Home env C:\oracle\ora81
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: INIT.ORA parameter compatible is 8.1.0
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: THIS VALUE IS ABOVE RECOMMENDED 8.1.0.0
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: INIT.ORA parameter os_authent_prefix is OPS$
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: This os_authent_prefix is correct
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: INIT.ORA parameter shared_pool_size is 52428800
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: INIT.ORA parameter optimizer_mode is RULE
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: Optimizer_mode is set correctly
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: INIT.ORA parameter remote_os_authent is TRUE
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: This value is correct
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: All init.ora parameters correct
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.p l: Script finished with known exit condition Tue Jun 1 08:24:44 2004
08:24:49: Get vrfyinitora.pl return code: 25
08:24:49: VRFYINITORA.PL - Successfull.
08:24:49: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat ckgistblspace.pl
C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace .pl:
################### Script started Tue Jun 1 08:24:49 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace .pl: Oracle_Home env C:\oracle\ora81
C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace .pl: No GIS tablespace exists
C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace .pl: Script finished with known exit condition Tue Jun 1 08:24:49 2004
08:24:54: Get ckgistblspace.pl return code: 5
08:24:54: CKGISTBLSPACE.PL - GIS Tablespace does not exist.
08:25:04: Autodesk GIS Design Server User is: GISX Autodesk GIS Design Server User Password = GISX
08:25:04: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat create_user.pl
Autodesk GIS Design Server User = GISX Autodesk GIS Design Server User Password = GISX TARGET Path = C:\ARCHIV~1\Autodesk\GISDES~1
C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.p l:
################### Script started Tue Jun 1 08:25:04 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.p l: Password GISX is correct for user GISX
C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.p l: User GISX is a member of the administrators group
C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.p l: Script finished with known exit condition Tue Jun 1 08:25:05 2004
08:25:09: Get create_user.pl return code: 25
08:25:09: CREATE_USER.PL - Successfull.
08:25:09: USER: Variable VISION_OWNER = GISX
08:26:07: PATH: CURRENT SYSTEM PATH= C:\NUTCROOT\bin;C:\NUTCROOT\bin\x11;C:\NUTCROOT\mk snt;C:\oracle\ora81\bin;C:\oracle\ora81\Apache\Per l\5.00503\bin\mswin32-x86;C:\Archivos de programa\Oracle\jre\1.1.7\bin;C:\WINNT\system32;C: \WINNT;C:\WINNT\System32\Wbem;C:\ARCHIV~1\Autodesk \GISDES~1\bin\IWINS
08:26:07: PATH: IWINS Path Found in Path environment. (C:\ARCHIV~1\Autodesk\GISDES~1\bin\IWINS )
08:26:07: REG: Key already set.
08:26:07: PATH: Updated SQL Path with C:\Archivos de programa\Autodesk\GIS Design Server\install\scripts\sql\dom\genapp_install SQLPATH
08:26:07: SET ENV: Variable ROOT = C:\ARCHIV~1\Autodesk\GISDES~1
08:26:07: SET ENV: Variable ARCH = IWINS
08:26:07: SET ENV: Variable TWO_TASK = BDMEGA
08:26:07: SET ENV: Variable NUT_SEC_ATTR_OFF = 1
08:26:07: SET ENV: Variable VISION_HOME = C:\ARCHIV~1\Autodesk\GISDES~1
08:26:07: GET ENV: Variable ComSpec = %SystemRoot%\system32\cmd.exe
08:26:07: SET ENV: Variable Shell =
08:26:07: SET ENV: Variable VISION_DOM_DDL_DIR = C:\ARCHIV~1\Autodesk\GISDES~1
08:26:10: SERVICES: Launched license manager service. C:\ARCHIV~1\Autodesk\GISDES~1\bin\IWINS\flexlm_ins tall.exe -c C:\ARCHIV~1\Autodesk\AUTODE~1\License -l c:\temp\flexLM.log -e C:\ARCHIV~1\Autodesk\GISDES~1\bin\IWINS\lmgrd.exe
08:26:10: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat chkservice2.pl
Service Name = "FLEXlm_License_Manager"
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.p l:
################### Script started Tue Jun 1 08:26:11 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.p l: Service to start is FLEXlm License Manager
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.p l: Service Active FLEXlm License Manager
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.p l: Current status of service is 1
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.p l: Service exists but not running
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.p l: Service has been started.
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.p l: Script finished with known exit condition Tue Jun 1 08:26:11 2004
08:26:15: Get chkservice2.pl return code: 25
08:26:15: CHKSERVICE2.PL - Successful.
08:26:15: GET ENV: Variable Shell =
08:26:17: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat chkservice.pl
Service Name = "AGDS_Orapswd_GISX"
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl :
################### Script started Tue Jun 1 08:26:17 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl : Service to start is AGDS Orapswd GISX
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl : Service Active AGDS Orapswd GISX
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl : Current status of service is 1
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl : Service exists but not running
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl : Service has been started.
C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl : Script finished with known exit condition Tue Jun 1 08:26:18 2004
08:26:22: Get chkservice.pl return code: 25
08:26:22: CHKSERVICE.PL - Successful.
08:26:23: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat vrfylicense.pl
process vserver: abnormal termination status code: 1
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l:
################### Script started Tue Jun 1 08:26:23 2004
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: Verify license during initial install
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: vision_user is GISX
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: license variable is 1
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: License Server local
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: License Server @SERV-GIS
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: \bin\IWINS\gmlp |
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: Warning - '(gmlp_init)': 1 : VSERVER: License get: `Licensed number of users already reached
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: Verify License: No license server available
C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.p l: Script finished with known exit condition Tue Jun 1 08:26:25 2004
08:26:28: Get vrfylicense.pl return code: 5
08:26:28: vrfylicense.PL - License not valid.
08:27:04: INSTALL COMPLETE: The Install has completed successfully.
