• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk GIS Design Server
    Problems with the installation of AGDS in the License
    133 Views, 0 Replies
    06-01-2004 05:26 AM
    Autodesk GIS Design Server Installation Log File
    ________________________________________________
    Install Date: 6-1-2004
    08:23:53: SYSTEM: Total system memory is 244460Kb and available memory is 1048576Kb.
    08:23:53: LIC: Variable ComputerNAme = SERV-GIS
    08:23:53: LIC: Variable adskflex_LICENSE_FILE not found.
    08:23:53: LIC: Variable adskflex_LICENSE_FILE = @SERV-GIS
    08:24:12: The Product license file as entered: C:\Archivos de programa\Autodesk\Autodesk License Manager\License
    08:24:12: The Product license file converted to DOS version: C:\ARCHIV~1\Autodesk\AUTODE~1\License
    08:24:12: The Product license file used to install flexlm: C:\ARCHIV~1\Autodesk\AUTODE~1\License
    08:24:29: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat sqlconnect.pl
    TWO_TASK = BDMEGA Sys Password = SYS System Password = MANAGER
    C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl:
    ################### Script started Tue Jun 1 08:24:30 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl: Oracle_Home env C:\oracle\ora81
    C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl: C:\CD_AUT~1\GIS_DE~1\install\scripts\sql\sql_ver.sql
    C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl: This sql is version 801070000
    C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl: This oracle is version 801070000
    C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl: Successful oracle connection
    C:\CD_AUT~1\GIS_DE~1\install\scripts\sqlconnect.pl: Script finished with known exit condition Tue Jun 1 08:24:36 2004
    08:24:39: Get sqlconnect.pl return code: 25
    08:24:39: SQLCONNECT.PL - Successfull.
    08:24:39: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat oracleversion.pl
    TWO_TASK = BDMEGA System Password = MANAGER SRC Path = C:\CD_AUT~1\GIS_DE~1
    C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion.pl:
    ################### Script started Tue Jun 1 08:24:39 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion.pl: Oracle_Home env C:\oracle\ora81
    C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion.pl: Current oracle version 801070000
    meets requirement of 801070000
    C:\CD_AUT~1\GIS_DE~1\install\scripts\oracleversion.pl: Script finished with known exit condition Tue Jun 1 08:24:40 2004
    08:24:44: Get oracleversion.pl return code: 25
    08:24:44: ORACLEVERSION.PL - Successfull.
    08:24:44: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat vrfyinitora.pl
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl:
    ################### Script started Tue Jun 1 08:24:44 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: Oracle_Home env C:\oracle\ora81
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: INIT.ORA parameter compatible is 8.1.0
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: THIS VALUE IS ABOVE RECOMMENDED 8.1.0.0
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: INIT.ORA parameter os_authent_prefix is OPS$
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: This os_authent_prefix is correct
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: INIT.ORA parameter shared_pool_size is 52428800
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: INIT.ORA parameter optimizer_mode is RULE
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: Optimizer_mode is set correctly
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: INIT.ORA parameter remote_os_authent is TRUE
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: This value is correct
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: All init.ora parameters correct
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfyinitora.pl: Script finished with known exit condition Tue Jun 1 08:24:44 2004
    08:24:49: Get vrfyinitora.pl return code: 25
    08:24:49: VRFYINITORA.PL - Successfull.
    08:24:49: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat ckgistblspace.pl
    C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace.pl:
    ################### Script started Tue Jun 1 08:24:49 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace.pl: Oracle_Home env C:\oracle\ora81
    C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace.pl: No GIS tablespace exists
    C:\CD_AUT~1\GIS_DE~1\install\scripts\ckgistblspace.pl: Script finished with known exit condition Tue Jun 1 08:24:49 2004
    08:24:54: Get ckgistblspace.pl return code: 5
    08:24:54: CKGISTBLSPACE.PL - GIS Tablespace does not exist.
    08:25:04: Autodesk GIS Design Server User is: GISX Autodesk GIS Design Server User Password = GISX
    08:25:04: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat create_user.pl
    Autodesk GIS Design Server User = GISX Autodesk GIS Design Server User Password = GISX TARGET Path = C:\ARCHIV~1\Autodesk\GISDES~1
    C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.pl:
    ################### Script started Tue Jun 1 08:25:04 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.pl: Password GISX is correct for user GISX
    C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.pl: User GISX is a member of the administrators group
    C:\CD_AUT~1\GIS_DE~1\install\scripts\create_user.pl: Script finished with known exit condition Tue Jun 1 08:25:05 2004
    08:25:09: Get create_user.pl return code: 25
    08:25:09: CREATE_USER.PL - Successfull.
    08:25:09: USER: Variable VISION_OWNER = GISX
    08:26:07: PATH: CURRENT SYSTEM PATH= C:\NUTCROOT\bin;C:\NUTCROOT\bin\x11;C:\NUTCROOT\mksnt;C:\oracle\ora81\bin;C:\oracle\ora81\Apache\Perl\5.00503\bin\mswin32-x86;C:\Archivos de programa\Oracle\jre\1.1.7\bin;C:\WINNT\system32;C:\WINNT;C:\WINNT\System32\Wbem;C:\ARCHIV~1\Autodesk\GISDES~1\bin\IWINS
    08:26:07: PATH: IWINS Path Found in Path environment. (C:\ARCHIV~1\Autodesk\GISDES~1\bin\IWINS )
    08:26:07: REG: Key already set.
    08:26:07: PATH: Updated SQL Path with C:\Archivos de programa\Autodesk\GIS Design Server\install\scripts\sql\dom\genapp_install SQLPATH
    08:26:07: SET ENV: Variable ROOT = C:\ARCHIV~1\Autodesk\GISDES~1
    08:26:07: SET ENV: Variable ARCH = IWINS
    08:26:07: SET ENV: Variable TWO_TASK = BDMEGA
    08:26:07: SET ENV: Variable NUT_SEC_ATTR_OFF = 1
    08:26:07: SET ENV: Variable VISION_HOME = C:\ARCHIV~1\Autodesk\GISDES~1
    08:26:07: GET ENV: Variable ComSpec = %SystemRoot%\system32\cmd.exe
    08:26:07: SET ENV: Variable Shell =
    08:26:07: SET ENV: Variable VISION_DOM_DDL_DIR = C:\ARCHIV~1\Autodesk\GISDES~1
    08:26:10: SERVICES: Launched license manager service. C:\ARCHIV~1\Autodesk\GISDES~1\bin\IWINS\flexlm_install.exe -c C:\ARCHIV~1\Autodesk\AUTODE~1\License -l c:\temp\flexLM.log -e C:\ARCHIV~1\Autodesk\GISDES~1\bin\IWINS\lmgrd.exe
    08:26:10: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat chkservice2.pl
    Service Name = "FLEXlm_License_Manager"
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.pl:
    ################### Script started Tue Jun 1 08:26:11 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.pl: Service to start is FLEXlm License Manager
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.pl: Service Active FLEXlm License Manager
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.pl: Current status of service is 1
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.pl: Service exists but not running
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.pl: Service has been started.
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice2.pl: Script finished with known exit condition Tue Jun 1 08:26:11 2004
    08:26:15: Get chkservice2.pl return code: 25
    08:26:15: CHKSERVICE2.PL - Successful.
    08:26:15: GET ENV: Variable Shell =
    08:26:17: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat chkservice.pl
    Service Name = "AGDS_Orapswd_GISX"
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl:
    ################### Script started Tue Jun 1 08:26:17 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl: Service to start is AGDS Orapswd GISX
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl: Service Active AGDS Orapswd GISX
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl: Current status of service is 1
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl: Service exists but not running
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl: Service has been started.
    C:\CD_AUT~1\GIS_DE~1\install\scripts\chkservice.pl: Script finished with known exit condition Tue Jun 1 08:26:18 2004
    08:26:22: Get chkservice.pl return code: 25
    08:26:22: CHKSERVICE.PL - Successful.
    08:26:23: Launching C:\CD_AUTODESCK\GIS_Design_Server\perlwrapper.bat vrfylicense.pl
    process vserver: abnormal termination status code: 1
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl:
    ################### Script started Tue Jun 1 08:26:23 2004
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: Verify license during initial install
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: vision_user is GISX
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: license variable is 1
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: License Server local
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: License Server @SERV-GIS
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: \bin\IWINS\gmlp |
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: Warning - '(gmlp_init)': 1 : VSERVER: License get: `Licensed number of users already reached
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: Verify License: No license server available
    C:\CD_AUT~1\GIS_DE~1\install\scripts\vrfylicense.pl: Script finished with known exit condition Tue Jun 1 08:26:25 2004
    08:26:28: Get vrfylicense.pl return code: 5
    08:26:28: vrfylicense.PL - License not valid.
    08:27:04: INSTALL COMPLETE: The Install has completed successfully.
    Please use plain text.
