Autodesk GIS Design Server
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Fayez, Sherine
Installing AGDS 7 Win 2k
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
119 Views, 1 Replies
07-16-2002 10:35 PM
I'm having a problem in installing the GIS Design
Server 7 on Windows 2000 Professional.
I've installed Oracle Enterprise 8.1.7 typical
installation and Oracle Client administrator installation.
Also I've completed the pre- installation found on
"installing_win2k" PDF file.
But I got the " Unable to connect to oracle"
message & the installation aborts, although I could connect to the oracle
using sql+.
using sql+.
Here are the two log files from the installation
procedure:
procedure:
Installation Log
File
________________________________________________
Install Date:
7-17-2002
16:17:11: SYSTEM: Total system memory is 261616Kb
and available memory is 1048576Kb.
16:17:11: GET ENV: Variable ORACLE_HOME =
D:\Oracle\oracle817
16:17:11: LIC: Variable ComputerNAme =
SHERINE
16:17:11: LIC: Variable adskflex_LICENSE_FILE not found.
16:17:11:
LIC: Variable adskflex_LICENSE_FILE = @SHERINE
16:17:52: Launching
F:\GIS_Design_Server\perlwrapper.bat sqlconnect.pl
TWO_TASK = sherine_gis
Sys Password = change_on_demand System Password = manager
16:17:57: Get
sqlconnect.pl return code: 5
16:17:57: SQLCONNECT.PL - No sys
connection.
16:17:59: Error in Oracle configuration.
Installation Log
File
Install Date:
7-17-2002
D:\Oracle\oracle817
SHERINE
16:17:11:
16:17:52: Launching
16:17:57: Get
connection.
Autodesk GIS Design Server Parameter
Log File
Install Date:
7-17-2002
[sqlconnect.pl]
Params=F:\GIS_D~13\install\scripts\perl\bin\perl.e xe
F:\GIS_D~13\install\scripts\sqlconnect.pl sherine_gis manager
change_on_demand
ReturnCode=5
Log File
Install Date:
7-17-2002
[sqlconnect.pl]
change_on_demand
ReturnCode=5
Can anyone tell me what the problem
is?
is?
Thanks in Advance,
Sherine
*Wasgarey, Jalal
Re: Installing AGDS 7 Win 2k
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-21-2002 06:15 PM in reply to:
*Fayez, Sherine
Sherine,
There appears to be some problem with the 'sys'
login. I notice you're entering the password as 'change_on_demand', when the
normal one in the manual is 'change_on_install'.
Try going into sqlplus and logging in as sys, using
the pasword 'change_on_demand'. If this does not work try 'change_on_install'.
If this works then you need to re-run the installation using the correct
password for sys.
password for sys.
If this does not work then I suggest you log a
support call with whoever is responsible for supporting your
product.
product.
Kind Regards,
Jalal Wasgarey
Autodesk Product Support GIS / Enterprise
WW Support & Services,
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"Sherine Fayez" <
href="mailto:sh.fayez@kemet.com.eg">sh.fayez@kemet.com.eg> wrote in
message
href="news:2223AE6ED252F3C907E5CD2C9154305B@in.WebX.maYIadrTaRb">news:2223AE6ED252F3C907E5CD2C915......
on "installing_win2k" PDF file.
using sql+.
procedure:
Installation Log
File
Install Date:
7-17-2002
= D:\Oracle\oracle817
SHERINE
found.
16:17:11: LIC: Variable adskflex_LICENSE_FILE =
@SHERINE
16:17:52: Launching F:\GIS_Design_Server\perlwrapper.bat
sqlconnect.pl
TWO_TASK = sherine_gis Sys Password = change_on_demand
16:17:57: Get sqlconnect.pl return code:
5
16:17:57: SQLCONNECT.PL - No sys connection.
configuration.
Parameter Log
File
Install Date:
7-17-2002
[sqlconnect.pl]
Params=F:\GIS_D~13\install\scripts\perl\bin\perl.exe
change_on_demand
ReturnCode=5
is?
Thanks in Advance,
Sherine
