• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk GIS Design Server
    *Paiano, Fabio
    How to create MapGuide SDF files from GIS Design Server Data with FEAT_NUM ?
    217 Views, 4 Replies
    02-01-2002 06:49 AM
    We are using Autodesk GIS Design Server and have an Autodesk Map application
    on top.
    We use the Autodesk Map application to draw the features that are in the
    Design Server database and we save a .DWG file from that. We now would like
    to create MapGuide SDF files from this data - we can do that using either
    the Menu/Map/Export to Autodesk MapGuide..., or we can use SDFLoader.
    The problem is: we need to put Design Server´s FEAT_NUM into the key column
    of the SDF file, but we don´t know how to do that.
    Has anyone ever done this?
    Fabio
    Please use plain text.
    *[Autodesk], Bruce Argue
    Re: How to create MapGuide SDF files from GIS Design Server Data with FEAT_NUM ?
    02-04-2002 05:42 PM in reply to: *Paiano, Fabio
    Hello Fabio,
    I am unable to come up with a direct answer to show you how to be able to
    export the contents in a DWG file directly into a SDF using FEAT_NUM from
    the G_MASTER table as the key. However, the following information from the
    Release Notes of the Autodesk GIS Design Server Provider for Autodesk
    MapGuide may interest you:
    "The Extension enables Autodesk MapGuide to access spatial and attribute
    data directly from a GIS Design Server database through the SDP (spatial
    data provider) architecture. This eliminates the requirement of converting
    the Autodesk GIS Design Server data to SDF (spatial data file) format before
    viewing with Autodesk MapGuide".
    Sincerely,
    Bruce Argue
    Enterprise Support Engineer
    APAC
    "Fabio Paiano" wrote in message
    news:6B85649D8AD36F91B3CA8BE9BE539F61@in.WebX.maYIadrTaRb...
    > Hello,
    application
    > on top.
    like
    column
    > Thanks,
    > Fabio
    *[Autodesk], Dirk Doerrenberg
    Re:
    02-04-2002 06:58 PM in reply to: *Paiano, Fabio
    Hello Fabio,
    with the current product there is no way to create this sdf keys
    automatically. The sdf files can use the key from Maps internal object data
    or from external database links.This is the same if you export directly from
    Map or use the sdfloader. The DesignServer Extension does not create this
    additional links in Map, but keeps the ones to the oracle database.
    I think the best approach would be to create a routine where the Extension
    renders features in Map and fills up an object data table at the same time
    including the FEAT_NUM value of the objects.
    regards,
    Dirk Doerrenberg
    Autodesk Product Support GIS
    Europe, Middle East, Africa
    "Bruce Argue [Autodesk]" wrote in message
    news:C0213C6429BFE1D7FD58DD309A93C117@in.WebX.maYIadrTaRb...
    > Hello Fabio,
    the
    converting
    before
    > Sincerely,
    > Bruce Argue
    > Autodesk
    > APAC
    > > Hello,
    > application
    > > on top.
    > like
    either
    > column
    > > Thanks,
    > > Fabio
    *Paiano, Fabio
    Re:
    02-07-2002 06:51 AM in reply to: *Paiano, Fabio
    Thanks a lot!
    But I wonder... In Autodesk Map 5 WITH the "Extension for Design Server"
    installed, you can open the Properties window for a given object and see a
    lot of Design Server´s information, like:
    Feature Number
    Network
    Layer
    Version
    Feature Code
    This information is somehow stored into the DWG, because if I save a DWG
    file and open in Autodesk Map WITHOUT creating a connection to the server,
    I´m still able to see these "Design Server Properties".
    So I wonder: there is no way of reading this info, either with SDF Loader,
    or with Map "Export to MapGuide" menu entry?
    It would be a lot better for me... I would prefer NOT working with MapGuide
    Data Extension for Design Server, if possible. For performance reasons, I
    would prefer working with SDF layers....
    Of course, if everything else fails, I can use SDF Toolkit, and create a
    program that reads the database directly and generates the SDF files... but
    I really would prefer if there were a faster and cheaper way of doing that.
    I´m open to any suggestions...
    "Dirk Doerrenberg [Autodesk]" escreveu na
    mensagem news:949E93D42312F4C63BB0F8683DFA8600@in.WebX.maYIadrTaRb...
    > Hello Fabio,
    data
    from
    > regards,
    > Dirk Doerrenberg
    message
    > > Hello Fabio,
    to
    from
    > the
    > converting
    > before
    > > Sincerely,
    > > Bruce Argue
    > > Autodesk
    > > APAC
    > > > Hello,
    > > application
    > > > on top.
    the
    > > like
    > either
    > > column
    > > > Thanks,
    > > > Fabio
    Re:
    02-07-2002 11:12 PM in reply to: *Paiano, Fabio
    Hello Fabio,
    I gave this a test and can reproduce it as you say. The properties are
    displayed in Autocad but you cannot access them from the properties display
    of the sdf export dialog. The export does only take the standard object
    properties of Autocad. When you save the dwg the sdfloader will only
    recognize unknown proxy objects.
    I think there are mainly two possibilities. Either create the objects via
    the Sdf Toolkit, or write some application in Map that will query the key
    from DesignServer and store it in an Object Data Table. The second
    possibility looks easier to me.
    Dirk Doerrenberg
    news:335D837A4EB4199883680646BDCBD54C@in.WebX.maYIadrTaRb...
    > Thanks a lot!
    > Feature Number
    > Network
    > Layer
    > Version
    > Feature Code
    MapGuide
    but
    that.
    na
    > > Hello Fabio,
    > data
    > from
    this
    Extension
    time
    > > regards,
    > > Dirk Doerrenberg
    > message
    > > > Hello Fabio,
    > to
    > from
    from
    > > the
    attribute
    (spatial
    > > converting
    > > before
    > > > Sincerely,
    > > > Bruce Argue
    > > > Autodesk
    > > > APAC
    > > > > Hello,
    > > > application
    > > > > on top.
    > the
    would
    > > > like
    > > either
    SDFLoader.
    > > > column
    > > > > Thanks,
    > > > > Fabio
