Autodesk GIS Design Server
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*Mena, Antoni
GenApp translatio n
Options
- Highlight
- Email to a Friend
91 Views, 2 Replies
09-02-2002 11:49 PM
I'm trying to translate the Generic Application VBasic components to
Spanish, so I'm following the detailed instructions in
localization_guide.pdf.
It seems to be very easy to do:
- download and unzip GenApplNls8000.zip
- translate the resource files in the extraction directory
- create newNls.LCID_ localizer components in DLLs,
following the sample code that is left in the extraction directory
- register the DLLs
Since it has'nt worked, I have simplified the problem by performing a
MsgBox("...") inside each method in the localizer, so the translation and
resource access is not necessary to ensure the problem correctness. It is
now supposed to appear a message if the localized was ever loaded and used,
but no message has ever appeared.
I have avoided debugging since there are many COM objects implicated and the
source code for the globalizer is not fully available.
To avoid problems with the LCIDs, I have created a class for 40A (for
Spanish), 0 (which is the code that some test applications have returned in
my system), 409 (for English), ...
It is still not working.
May I have forgotten something?
The globalizer is supposed to be codified to always success, even if the
localizer cannot be found. I have seen that every call to
Globalizer.LocalizeString() returns the default_string parameter. Something
is going wrong, but what? There is no error message!
Has anybody experienced similar problems?
What am I doing wrong?
Thank-you in advance,
Antoni Mena.
- create new
- register the DLLs
Antoni Mena.
*Chye, Heng Lee
Re: GenApp translatio n
Options
- Highlight
- Email to a Friend
09-08-2002 06:52 PM in reply to:
*Mena, Antoni
Hi Antoni
The new that you want to implement is obtained internally within the
GenApp application from the Windows API call GetUserDefaultLCID().
Have you tried to set your user locale from Control Panel ,Regional Settings
to corresponds to ?
Lee Chye
Enterprise Support Engineer
Autodesk Professional Services
"Antoni Mena" wrote in message
news:0347D525A6C951A7E2534AC0C2A05A5C@in.WebX.maYI adrTaRb...
> Hi,
> - register the DLLs
used,
the
in
Something
> Antoni Mena.
The new
to corresponds to
Lee Chye
"Antoni Mena"
> Hi,
> - create new
> - register the DLLs
used,
the
in
Something
> Antoni Mena.
*Mena, Antoni
Re:
Options
- Highlight
- Email to a Friend
09-15-2002 10:41 PM in reply to:
*Mena, Antoni
I have run that API call within a Visual C++ application and the result
has been "C0A" in hex.
I have already implemented the class "AeScVisualPrjMgrNls.LCID_c0a"
(that is the name taken from the Windows registry) and it is still not
working. The component is not translated and there is no message box
displayed.
What could I do to find where the problem is?
Is all the Globalizer source code available? Where?
Thank-you!!
"Heng Lee Chye" escribió en el mensaje
news:F0BA8B4EC0D07F75412F10E28D9ABC78@in.WebX.maYI adrTaRb...
> Hi Antoni
the
Settings
> to corresponds to ?
> Lee Chye
> > Hi,
> > - register the DLLs
and
is
> used,
> the
> in
> Something
> > Antoni Mena.
displayed.
Thank-you!!
"Heng Lee Chye"
> Hi Antoni
> The new
the
Settings
> to corresponds to
> Lee Chye
> "Antoni Mena"
> > Hi,
> > - create new
> > - register the DLLs
and
is
> used,
> the
> in
> Something
> > Antoni Mena.
