• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk GIS Design Server
    *Mena, Antoni
    GenApp translation
    92 Views, 2 Replies
    09-02-2002 11:49 PM
    I'm trying to translate the Generic Application VBasic components to
    Spanish, so I'm following the detailed instructions in
    localization_guide.pdf.
    It seems to be very easy to do:
    - download and unzip GenApplNls8000.zip
    - translate the resource files in the extraction directory
    - create new Nls.LCID_ localizer components in DLLs,
    following the sample code that is left in the extraction directory
    - register the DLLs
    Since it has'nt worked, I have simplified the problem by performing a
    MsgBox("...") inside each method in the localizer, so the translation and
    resource access is not necessary to ensure the problem correctness. It is
    now supposed to appear a message if the localized was ever loaded and used,
    but no message has ever appeared.
    I have avoided debugging since there are many COM objects implicated and the
    source code for the globalizer is not fully available.
    To avoid problems with the LCIDs, I have created a class for 40A (for
    Spanish), 0 (which is the code that some test applications have returned in
    my system), 409 (for English), ...
    It is still not working.
    May I have forgotten something?
    The globalizer is supposed to be codified to always success, even if the
    localizer cannot be found. I have seen that every call to
    Globalizer.LocalizeString() returns the default_string parameter. Something
    is going wrong, but what? There is no error message!
    Has anybody experienced similar problems?
    What am I doing wrong?
    Thank-you in advance,
    Antoni Mena.
    Please use plain text.
    *Chye, Heng Lee
    Re: GenApp translation
    09-08-2002 06:52 PM in reply to: *Mena, Antoni
    Hi Antoni
    The new that you want to implement is obtained internally within the
    GenApp application from the Windows API call GetUserDefaultLCID().
    Have you tried to set your user locale from Control Panel ,Regional Settings
    to corresponds to ?
    Lee Chye
    Enterprise Support Engineer
    Autodesk Professional Services
    "Antoni Mena" wrote in message
    news:0347D525A6C951A7E2534AC0C2A05A5C@in.WebX.maYIadrTaRb...
    > Hi,
    > - register the DLLs
    used,
    the
    in
    Something
    > Antoni Mena.
    *Mena, Antoni
    Re:
    09-15-2002 10:41 PM in reply to: *Mena, Antoni
    I have run that API call within a Visual C++ application and the result
    has been "C0A" in hex.
    I have already implemented the class "AeScVisualPrjMgrNls.LCID_c0a"
    (that is the name taken from the Windows registry) and it is still not
    working. The component is not translated and there is no message box
    displayed.
    What could I do to find where the problem is?
    Is all the Globalizer source code available? Where?
    Thank-you!!
    "Heng Lee Chye" escribió en el mensaje
    news:F0BA8B4EC0D07F75412F10E28D9ABC78@in.WebX.maYIadrTaRb...
    > Hi Antoni
    the
    Settings
    > to corresponds to ?
    > Lee Chye
    > > Hi,
    > > - register the DLLs
    and
    is
    > used,
    > the
    > in
    > Something
    > > Antoni Mena.
