• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk GIS Design Server
    New Member
    GML command retrieve_travel and coordinate systems
    103 Views, 0 Replies
    04-29-2004 01:16 PM
    Issue
    When a database uses different coordinate systems for storage and input/output, the GML command retrieve_travel ignores the measurement unit given.
    Solution
    Meters are the hard-coded default for all latitude/longitude-derived coordinate systems. Therefore, it is necessary to convert the travel distance to meters when you are using different coordinate systems for the storage and input/output of your data.
    This can be done either by multiplying by a known scaling factor, or using the GML command retrieve unit_conversion as follows:
    setup coordinate system {fe_ll};
    retrieve unit_conversion length for $distance_feet into distance_metres;
    setup coordinate system {fe_lc};
    Please use plain text.
