Autodesk GIS Design Server
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
GML command retrieve_t ravel and coordinate systems
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
104 Views, 0 Replies
04-29-2004 01:16 PM
Issue
When a database uses different coordinate systems for storage and input/output, the GML command retrieve_travel ignores the measurement unit given.
Solution
Meters are the hard-coded default for all latitude/longitude-derived coordinate systems. Therefore, it is necessary to convert the travel distance to meters when you are using different coordinate systems for the storage and input/output of your data.
This can be done either by multiplying by a known scaling factor, or using the GML command retrieve unit_conversion as follows:
setup coordinate system {fe_ll};
retrieve unit_conversion length for $distance_feet into distance_metres;
setup coordinate system {fe_lc};
Solution
