• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk GIS Design Server
    *Mena, Antoni
    Error while managing LTC versions
    104 Views, 1 Replies
    07-29-2002 10:03 PM
    We are trying to use LTC (Long Transaction Cartridge) within the Generic
    Application in AGDS 8.0, upon Windows 2000 (client and server), ORACLE 8.1.7
    and Autodesk Map 5.0 in Spanish.
    After following all the installation and configuration instructions, the
    system hangs on when we try to manage versions.
    We have tried to access LTC functionalities by two ways:
    1) using the generic application's Component Browser: Autodesk Map 5 hangs
    on after entering a version and performing any further operation, like
    showing the version properties (the properties dialog box appear, but AMap
    is hung on, not responding to any mouse or keyboard event)
    When we make the version active at first time a message appears, but it
    seems that
    everythig is still working. The message is "Llamada a procedimiento o
    argumento no
    válidos" (in english, this message would be something like: "Not valid
    Procedure
    call or arguments")
    2) calling vewProjectManager.Load() by VB code:
    Private Sub iniciarProjectManager()
    Set unaSesion = New vewSession
    Set unaConexion = unaSesion.Connection
    ' startup the Message Window
    unaSesion.AutoMessageWindow = True
    'Connection initialization
    unaConexion.UserName = ...
    unaConexion.Password = ...
    unaConexion.port = ...
    unaConexion.HostName = ...
    ' connect the PC Client to the Server
    unaConexion.Connect
    ' Write the Connected OK message to the Message Window
    Call unaSesion.GmlExec("mes {Connected OK!};", vewGECComplete)
    'Program Manager initialization
    Set unProjectManager = New vewProjectManager
    'Session to project assignation
    Set unProjectManager.Session = unaSesion
    'Loading projects
    unProjectManager.Load (False)
    End Sub
    This operation results in the following error: "Visual Basic: Error 1211
    en tiempo de ejecución: .\Accessdb.cpp: 464: No spatial db, in
    dbAccessData::GetActive".
    En this second case the same error message appears when we are connected
    to
    an AGDS Oracle Spatial DB as well as when we are using a traditional AGDS
    DB.
    ORACLE has been fully installed, AGDS has been fully installed as well and
    we have followed all the LTC configuration steps (in administration guide
    and in Data Cartridges guide).
    What is happening?
    Thank-you,
    Antoni Mena
    amena@sysigsa.com
    Please use plain text.
    *[Autodesk], Dirk Doerrenberg
    Re: Error while managing LTC versions
    08-18-2002 10:28 PM in reply to: *Mena, Antoni
    Hello Antoni,
    In case you installed Autodesk GIS Designserver and
    checked also the installation of the Long Transaction and the Advanced Security
    Cartridge, you should be able to use it from the components browser interface
    via the version category.
    There must be something gone wrong during the
    installation when this is causing the system to hang. Please check first the
    AGDSInstall.log if there are any errors reported.
    Following the Data cartridges manual you should
    check if
    a) the UTL_RAW PL/SQL package is installed on the
    Oracle server
    b) the users C$VIS_SE_1, C$VIS_SE_1, C$VIS_PL_1
    exist on the database
    c) check if the version is created in the
    G_VERSION_DEPEND table of the user related to the specific
    database.
    hope this helps,
    Dirk Doerrenberg
    size=2>Enterprise Product Support
    WW Support & Services,
