• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk GIS Design Server
    *RexLee
    Can not bulk classify using GenAppDB.
    75 Views, 1 Replies
    09-16-2002 01:49 PM
    I installed AGDS 8.0 Client component along manual.
    1. run Autodesk MAP.
    2. draw several line.
    3. run bulk classify.
    4. then success message is promped.
    There is nothing record in G_Master table in GenAppDB.
    Please use plain text.
    *[Autodesk], Richard Horrocks
    Re: Can not bulk classify using GenAppDB.
    09-23-2002 12:22 AM in reply to: *RexLee
    Could be that the problem that you have is because you are digitizing the
    element on the DWG outside of the extension of the database, then when you
    run the Classify, doesn't find anything in the database extension and for
    that reason doesn't populate the G_MASTER table.
    If you already have an element in the database, one thing that you can do is
    do a query to that element and display it, then you will be inside the
    extension. An other way is navigation in the DWG file to the right
    coordinates using the Autodesk Map tools. Also check the template file.
    Other thing that could cause that, but is not probable if you are using the
    application out of the box, is that the application is set it to use the
    AutoCad Reactors instead of the classify. To check those settings see the
    release notes Pag. 24 under the title "Object Rules Reactors Are Not Enabled
    by Default"
    I hope this help
    Richard
    "RexLee" wrote in message
    news:1637DECB65297475E54A72C6E966FB9E@in.WebX.maYIadrTaRb...
