• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Freewheel
    Member
    transparent surface problem
    66 Views, 2 Replies
    07-17-2007 08:58 AM
    I am trying to upload an assembly includes a cylinder that I have extruded in Inventor. The surface of this cylinder is Polycarbonate (clear), so the parts inside it may be visible. When I save this assembly as a .dwf file and view it with Autodesk Design Review, I am able to view the clear surface and everything inside it perfectly. However, when I open it with Autodesk Freewheel, only 1/4 of the transparent cylinder shows up. Any ideas? Thanks.
    Please use plain text.
    *Scott Sheppard - Autodesk
    Re: transparent surface problem
    07-17-2007 01:14 PM in reply to: mattd7
    Please provide the DWF as a test case.
    wrote in message news:5660266@discussion.autodesk.com...
    Thanks.
    *Gyuri Ordody [Autodesk]
    08-27-2007 11:13 AM in reply to: mattd7
    No need to upload, I have reproduced the problem.
    Gyuri
    > Thanks.
