• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Freewheel
    New Member
    btimby
    ?path=https://... not working.
    1046 Views, 2 Replies
    04-14-2011 01:18 PM
    Hi, I am trying to use Freewheel on our site, and our site runs over SSL. Therefore the URL I pass via the path= parameter is https://. When I do this, I get the following error:
    The requested DWF is not valid.
    If I use http:// it works just fine. Also, I can see from my HTTP server log that I am in fact sending the file over HTTP or HTTPS, so the only difference would be the server certificate validation that is happening within your software.
    I imagine this must be because our certificate is not valid as far as your HTTPS client is concerned. The UserAgent shows WinHttp.WinHttpRequest.5, which I assume is a Microsoft HTTP component you are using. Are you by chance missing the GlobalSign root certificate on your servers?
    http://www.globalsign.com/support/rootinstall.html
    Thank you for your consideration.
    Please use plain text.
    New Member
    btimby
    Re: ?path=https://... not working.
    04-14-2011 04:46 PM in reply to: btimby
    I tried a different https:// site with a certificate from GoDaddy and it worked fine.
    I am fairly certain now that it is this specific certificate (more accurately, the CA).
    Thanks.
    Board Manager
    05-02-2011 05:57 PM in reply to: btimby
    Thanks for the detective work.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
