• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Freewheel
    Active Member
    raul
    Unable to publish Freewheel nor Uninstall ADR 2011
    905 Views, 5 Replies
    10-02-2010 08:28 AM
    Hi
    I tried to save my dwf to Freewheel from ADR 2011, but it constantly takes me to the labs website. So tried to repair or uninstall ADR2011 and got error 2738: could not access vbscript..
    912iB61A75102E5233FF
    Running on Win 7 64bit.
    Help, please!
    Raul
    Please use plain text.
    Active Member
    raul
    Re: Unable to publish Freewheel nor Uninstall ADR 2011
    10-10-2010 09:34 AM in reply to: raul
    I finally solved the uninstall issue, it was a registry error. But re-install did not solve the "save to freewheel" problem. ADR 2011 should not need any plug-ins, right? Why does it take me to ShareNow website then?
    Help appreciated,
    Raul
    Board Manager
    10-13-2010 08:15 AM in reply to: raul
    Correct. ADR should not need you to download and install the ShareNowe plugin. Unlike for 2010, it coems with ADR. IT is acting as if this part of the application did not get installed.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Active Member
    raul
    10-24-2010 01:46 PM in reply to: scott.sheppard
    After several tries of uninstalling, cleaning registry, reinstalling ADR 2011 bundle there is no change. I cannot save to freewheel. So how can I get it to work?
    Raul
    Board Manager
    10-26-2010 04:03 PM in reply to: raul
    The easiest thing to do would be a 2 step process.
    1. Publish the DWF.
    2. Use the file open of Project Freewheel to load the file.
    After that, it;'s the same as if you published right from Autodesk Design Review to Project Freewheel.
    Scott Sheppard
    Program Manager
    Autodesk Labs
    Autodesk, Inc.
    Active Member
    raul
    11-13-2010 04:27 AM in reply to: scott.sheppard
    Thanks Scott,
    sure this workaround can do. But still the problem needs solving. I have tried several computers in the office with different configrations, the command simply does not work. I hope this annoying issue get fixed, because simple and effective sharing the dwfs is the main idea of using them...
    Cheers
    Raul
