• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Freewheel
    Valued Contributor
    Sharenow - where is it?
    179 Views, 8 Replies
    02-20-2008 09:00 AM
    I installed sharenow for Revit, but when I open Revit, I see nothing new - no external tools no toolbars, etc.
    As there is no documentation with the install I have no idea where to start...
    i am running Revit 2008 (20070810_1700) in Vista x64.
    PARTIAL REVIT.INI FILE:
    [ExternalCommands]
    ECCount=7
    ECName1= HelloWorld2
    ECClassName1= HelloWorld2.HelloWorld2
    ECAssembly1= C:\Users\deagle\Documents\Visual Studio 2008\Projects\HelloWorld2\HelloWorld2\bin\Debug\HelloWorld2.dll
    ECName2="Acquire from Google Earth"
    ECClassName2=GEAcquirement.Acquirement
    ECAssembly2="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
    ECName3="Publish to Google Earth"
    ECClassName3=GEPublish.Publish
    ECAssembly3="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
    ECName4="Import Google Earth File (KML/KMZ)"
    ECClassName4=GEImport.Import
    ECAssembly4="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
    ECName5="Export Google Earth File (KML/KMZ)"
    ECClassName5=GEExport.Export
    ECAssembly5="C:\Program Files (x86)\Autodesk\Revit 2008 Globe Link\Revit2008GlobeLink.dll"
    ECName6="Batch Print"
    ECClassName6=Revit.PrintHarness.PrintHarnessAPI
    ECAssembly6="C:\Program Files (x86)\Autodesk\Batch Print for Revit 2008\BatchPrint.dll"
    ECName7="Worksharing Monitor"
    ECClassName7=WorkSharingCommand.WorkSharingCommand
    ECAssembly7="C:\Program Files (x86)\Autodesk\Worksharing Monitor for Revit 2008\WorkSharingCommand.dll"
    [ExternalApplications]
    EACount=1
    EAClassName1=Autodesk.Freewheel.RevitAddin.ShareNowApp
    EAAssembly1=C:\Program Files (x86)\Revit Architecture 2008\Program\\RevitShareNow.dll
    EAName2="Worksharing Monitor Lib for Revit 2008"
    EAClassName2=WorkSharingLib.ExternalApplication
    EAAssembly2="C:\Program Files (x86)\Autodesk\Worksharing Monitor for Revit 2008\WorkSharingLib.dll"
    Please use plain text.
    *Scott Sheppard - Autodesk
    Re: Sharenow - where is it?
    02-20-2008 03:21 PM in reply to: Takuwind
    To get started:
    1.. You download the installer ZIP file.
    2.. You unzip it.
    3.. You pick the MSI installer that you want: 32-bit AutoCAD 2008, 64-bit
    AutoCAD 2008, Inventor 2008, Inventor LT, or Revit 2008. You execute the
    desired installer.
    4.. The next time you fire up your application, ShareNow is available.
    This invokes new functionality.
    Autodesk Revit: Icons for sharing the current view of the building
    information model and sharing all views of the building information model
    appear.
    There's a YouTube video you can view:
    http://www.youtube.com/watch?v=YWr5OmYQpiM
    wrote in message news:5853366@discussion.autodesk.com...
    start...
    [ExternalCommands]
    ECCount=7
    EACount=1
    Valued Contributor
    02-20-2008 03:25 PM in reply to: Takuwind
    As I mentioned above, I already installed ShareNow.
    It does not show up anywhere.
    02-21-2008 06:18 AM in reply to: Takuwind
    Do you have more than one version of Revit on your computer? Our installer
    is not that smart. It adds ShareNow to the first Revit it finds, which might
    not be the right one.
    wrote in message news:5853947@discussion.autodesk.com...
    Valued Contributor
    02-21-2008 08:36 AM in reply to: Takuwind
    No - only one version.
    Is your installer able to find it in the C:\Program Files (x86) folder?
    02-26-2008 08:35 AM in reply to: Takuwind
    I have not tried this. I will ask the development team to try it. The
    empirical evidence suggests "No."
    wrote in message news:5854672@discussion.autodesk.com...
    02-28-2008 01:23 PM in reply to: Takuwind
    you need EACount=2
    EACount=2
    EACl assName1=Autodesk.Freewheel.RevitAddin.ShareNowApp
    EAAssembly2="C:\Pro gram Files (x86)\Autodesk\Worksharing Monitor for Revit 2008\WorkSharingLib.dll"
    03-06-2008 07:38 AM in reply to: Takuwind
    We have determined that this is a problem on a 64-bit machine. We plan to
    address it in our next release.
    New Member
    08-18-2008 03:20 AM in reply to: Takuwind
    Have you find a solution to start batch in vista x64?
