We want as many standard panels apply and therefore the panels that are too long on the construction freshly cut.
I want to mimic in Inventor by the standaard panel which is too long to cut.
If I've done this process and then sync with acad the sketch remains visible.
I want the sketch also become shortened so it fits the structural walls in the acad xref.
Solved by j.vanderheijden. Go to Solution.
Hi -
If I'm understanding what you're saying, you've applied a simple sketch as the 2d representation of the Inventor model, and you are then making an adjustment to a parameter, which causes the Inventor model to be a different size. But, the sketch isn't updating -- right?
Unfortunately, this currently isn't supported; the sketch will always be a single size.
Jeff
Hi Jeff
I send drawings to Xuesong because the zip file was to larg to post.
I hope the drawings make it clear to understand my problem
I use my own panels who are not assets.
I place them with imates and then it works white the sketch.
I can cut the panels in Inventor and sync to acad and the sketch wil updat.
Great!
