Autodesk Factory Design Suite General Discussion
j.vanderheijden
Message 1 of 1 (51 Views)
sheet metal style
51 Views, 0 Replies
12-06-2012 11:03 AM
I thought I knew but there is something else.
I have various styles created my behalf sheet metal panels.
Now I want from the base all four sides separate places because we want to be flexible in each side separately adjust the height.
The corners are in a certain way to each other and is dependent on the supplier there for the various styles.
When I made my panel and I change of style I had hoped that the corners would also change, but that does not happen.
If I place the four sides in the same command then the corners change after changing the style.
Now I can do a Corner Seam, but when I change the style, the corners not change.
Am I missing something or is this the manner of Inventor?
I attach two parts where the different corners in.
I want to switch between the two styles(corners) in one part.
Mvg Jos
Your drawings are only as good as the symbols that complete them...
