• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Factory Design Suite
    j.vanderheijden
    Re: linked dwg overlay
    08-16-2012 05:56 AM in reply to: jeff.pek
    Or are you using Remote Desktop from the server, and accessing your PC?
    This is whate we do.
    Mvg Jos
    Your drawings are only as good as the symbols that complete them...
    Please use plain text.
    Employee
    08-16-2012 06:16 AM in reply to: j.vanderheijden
    OK, so you're saying that when you log into your PC via Remote Desktop you don't see the Factory tab, but logged in directly you do?
    I've never seen anything like that, and I can't imagine what would cause it. Are you logged in as the same user in both scenarios?
    When you go to the ApplicationPlugins directory that I mentioned earlier, what do you see (in both log-in scenarios)?
      Jeff
    j.vanderheijden
    08-16-2012 06:27 AM in reply to: jeff.pek
    In both i see the same.
    The only different is the Cuix file.
    When i log into my pc i see there is the cuix file and when i log into Remote there is no cuix file.
    Mvg Jos
    j.vanderheijden
    08-16-2012 06:56 AM in reply to: jeff.pek
    Btw i use two different inlog names.
    Mvg Jos
    Employee
    08-16-2012 06:58 AM in reply to: j.vanderheijden
    That must have something to do with it.
    Did you try resetting the profile in the scenario where it's not working?
    Jeff
    j.vanderheijden
    08-16-2012 07:14 AM in reply to: jeff.pek
    Yes, i reset my profile i even tried Vanilla but it is still not working.
    Am I the only one with this problem, I can imagine that there are multiple users who using a remote desktop at work.
    Mvg Jos
    Employee
    08-16-2012 06:15 PM in reply to: j.vanderheijden
    Spoiler
    Yes, we often use Remote Desktop from one PC to access another PC. But we are not working with this senario, from my own PC login with a serevr account, and then remote to my own PC again. could you let me know the benefit in this senario?
    Employee
    08-16-2012 09:56 PM in reply to: j.vanderheijden
    Hi - Yes, you seem to be the only one with this problem - as I mentioned, we use Remote Desktop all the time, and don't see this. Have you tried logging into your PC directly with the login that you use with Remote Desktop? I'd suspect you'd see the same thing. Jeff
    j.vanderheijden
    08-16-2012 11:25 PM in reply to: j.vanderheijden
    When i login to the Remote i have two explorers, see the attachment.
    To the left its the way when i go to the server and i don't see my own pc.
    To the right its the way when i go to my own pc.
    When i loggin to my pc i don't see the server, partition H:M:smileytongue:
    I have made a new acad profile at home and used it at my company but that is not working.
    Mvg Jos
    j.vanderheijden
    08-16-2012 11:49 PM in reply to: j.vanderheijden
    I have another problem, everytime i start acad i habe to activate my profile.
    Everytime it switch back to Vanilla.
    Could it be that i have problems with the startup script when i loggin to the server?
    I also loaded the Fact cui with menuload and then i see the tab in the ribbon but its not compleet
    Mvg Jos
