I have a part made with a connector on both sides and four insertion points.
When i place the parts the connectors do not seem to work well.
The head sides are not close together.
Does anyone have an idea, do I have the connectors placed on another place?
Has it something to do with the direction of the triad?
I help modify the connector as attached. Based on the model, the Z direction should be vertical with landing sureface and the X direction should be with model length direction. while we can ignore the Y direction definition.
-Xuesong
Are the directions of the Z,X,Y always the same?
Can it be differunt by other parts?
In general, the X direction will be vertical to the edge or face selected. However,the directions will should be changed to adjust to how the asset connect to another.
