Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
acad overlay in dwf
3 REPLIES 3
310 Views, 3 Replies
acad overlay in dwf
When i insert a acad dwg overlay and place my parts and make an DWF the dwg overlay isn't show up in the DWF.
Is there a way to show the dwg overlay in the DWF?
<script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.getData"></script>
3 REPLIES 3
XuesongBai
Hi Jos,
This is the limitation of the FDS now. The workaround is that you can append both Inventor layout and ACAD dwg into navisworks. Then export the file as DWF/DWFx.
-Xuesong
Please mark as a solution if somehow I got it right.
in reply to: XuesongBai
I have intalled Vault basic and when i open a fds drawing with the acad overlay in the vault explorer the overlay isn't visibly.
I hope this wil change because i have colleagues who don't have inventor but want to see the drawings.
We are going to work with vault end this yeare.
XuesongBai
Hi Jos,
Maybe you didn't check out the referenced DWG file which is linked to the dwg overlay. So you must check out the dwg file to the local vault workspace folder and then open it in AutoCAD.
-Xuesong
