Using part parameter in factory assembly
Logos_Atum
Advisor Advisor
Message 1 of 11
Logos_Atum
HEllo there,
how can i use a part parameter which is in an asset in a factory assembly.
The array command is to accept the input of the width parameter of the asset.
Ilogic to be used?
Dogs aren´t flammable.
Replies (10)
Message 2 of 11
XuesongBai
Hi There,
Yes, we need to link the parameter of asset in factory layout by iLogic. The sample iLogic code is as
d3=Parameter("iLogic Control:1", "Length")
 And link the value in the array in layout assembly.
Please see the details in the snapshot attached.
-Xuesong
Please mark as a solution if somehow I got it right.
Message 3 of 11
Logos_Atum
Mr Xuesong - what would i do without you - thank you very much for your professional expertise and great answers. Im working on the solution right now
Bless you 🙂
Message 4 of 11
Logos_Atum
I trying but maybe you can help me one more time.
Do i need to define a rule in the asset too?
Message 5 of 11
Logos_Atum
Where to define "ilogic Control:1" ?
This is the first time i´m using i logic - be patient.
I am all glad that it´s possible to do this but i need advise still
Message 6 of 11
XuesongBai
Hi There,
you need not to define the ilogic in the specific asset. It is OK to define it in layout assembly. "iLogic Control" is just name of a part which is placed in the assembly and the parameter of the part will conrol the array. Once the value of part parameter is changed, the array will be updated too. Maybe you need to run the ilogc rule and update the document manually.
Anyway, I attached the simple sample for your reference.
-Xuesong
Message 7 of 11
Logos_Atum
Thank you - i ´m working on it... perhaps i will ask some more questions 😉
Great support!
Message 8 of 11
Logos_Atum
I decided to send you the problem i´m working on...
Perhaps this will clarify it for me for i know the matter better.
I don´t know yet which files to include for the pack and go to work properly, so i had a look into your zip file.
It´s in german- ask me whatever you need to know. The box needs to be the source for the array´s offset to prevent the boxes to overlap.
As long as you look into my problem i will look into your example.
Thanks in advance
Message 9 of 11
XuesongBai
OK,Please send me the file by Xuesong.bai@autodesk.com
-Xuesong
Message 10 of 11
Logos_Atum
Hello there,
there still is a problem getting the asset name.
The program tells me there is no such instance.
I will send the corresponding files to you and hope to get this issue resolved
Message 11 of 11
XuesongBai
Hi Daniel,
Please use the name of occurence in the browser,say Regal DT:1.
Breite=Parameter("Regal DT:1", "Breite")
-Xuesong
