is possible to convert structures like walls, stairs, windows created in architecture to the Inventor 3D factory model? If i send dwg from architecture to Inventor i can see 3D models of machines but structures made in architecture only in wire model.
Hi there,
The answer is yes. The workflow should be like this:
1,Covert Architecture stuff like Wall, Windows, etc to 3D solid by CONVERTO3DSOLIDS command in AutoCAD Architecture
2,Import it into Inventor as factory asset by Import DWG Solids in Factory Inventor
-Xuesong
