Autodesk Factory Design Suite
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Send to Inventor Button - iLogic Rules and Forms Omitted
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When using the 'Send to Inventor' button in AutoCAD Architecture, the iLogic rules in my Factory Layout template are not brought in to the new Layout created. I have selected the desired template in the Templates tab of the Inventor factory options, is there another location that I need to specify the template to be used? All the iLogic is brought in as expected when creating a new Factory Layout from template as normal from Inventor so this seems to be a problem with the 'Send to Inventor' button itself. Can anyone advise?
Re: Send to Inventor Button - iLogic Rules and Forms Omitted
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Supposed you are using the Win 7 OS.So there is two templates for Metric and Imperial in the C:\Users\Public\Documents\Autodesk\Inventor 2012\Templates\Factory. You need to create the ilogic rule in them. So if you new 2D layout in ACAD by Metric template, then Send to Inventor will select the 3D metric template too. Vice versa.
-Xuesong
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Superb! Thank you very much for your help Xuesong.
