• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Factory Design Suite
    Active Contributor
    CadlineSupport
    Accepted Solution
    Send to Inventor Button - iLogic Rules and Forms Omitted
    204 Views, 2 Replies
    03-08-2012 08:21 AM
    When using the 'Send to Inventor' button in AutoCAD Architecture, the iLogic rules in my Factory Layout template are not brought in to the new Layout created. I have selected the desired template in the Templates tab of the Inventor factory options, is there another location that I need to specify the template to be used? All the iLogic is brought in as expected when creating a new Factory Layout from template as normal from Inventor so this seems to be a problem with the 'Send to Inventor' button itself. Can anyone advise?
    Please use plain text.
    Employee
    Re: Send to Inventor Button - iLogic Rules and Forms Omitted
    03-08-2012 05:57 PM in reply to: CadlineSupport
    Supposed you are using the Win 7 OS.So there is two templates for Metric and Imperial in the C:\Users\Public\Documents\Autodesk\Inventor 2012\Templates\Factory. You need to create the ilogic rule in them. So if you new 2D layout in ACAD by Metric template, then Send to Inventor will select the 3D metric template too. Vice versa.
    -Xuesong
    Active Contributor
    CadlineSupport
    03-09-2012 01:15 AM in reply to: XuesongBai
    Superb! Thank you very much for your help Xuesong.
