What's the best way to share a number of Factory Users Assets with a privite selected group of people?
Solved by XuesongBai. Go to Solution.
Hi Peter -
This isn't possible today with Cloud-based assets.
The only thing is to publish them to a commonly-available network file share.
We hope to be able to deliver controlled sharing of Cloud-based assets in a future release.
Jeff
Hi Peter,
Are the people in the same company? Or can they get the assets from shared network folder? Or are they using the vault?
-Xuesong
In this case, yes, we want to share assets between Autodesk employees for demo preparation etc...which cannot be made public.
So we can add a common server location and define the server path as an additional library location in the project file. But I wanted to know the workflow to share assets between project members without having access to a common server location.
Hi Peter,
In this case, I recommend you shared the factory user assets by Vault. So the project members can access to vault,although they are out of office.
Attached is the workflow I was writing as workflow test, hope that will be helpful to you.
-Xuesong
