Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
NavisWorks 2014 SP1 Notice
9 REPLIES 9
Message 1 of 10
DarrenP
2129 Views, 9 Replies
Do not install service pack 1 for navisworks 2014
reported issues: http://forums.autodesk.com/t5/Autodesk-Navisworks/Memory-Settings/td-p/4335294 and here: http://forums.autodesk.com/t5/Autodesk-Navisworks/NavisWorks-2014-SP1-is-out/td-p/4335454
the service packs causes navisworks to instantly crash to an Autodesk CER
DarrenP
9 REPLIES 9
Message 2 of 10
DarrenP
in reply to: DarrenP
this seems to only effect navisworks from the factory design suite 2014
i tested the service pack on a non suite version of navisworks 2014
and navisworks from the building design suite 2014 the crash does not happen
DarrenP
Message 3 of 10
DarrenP
i have a case open with autodesk
DarrenP
Message 4 of 10
adsk_loren
The Factory team is working on a Hotfix for this issue.
Loren
Message 5 of 10
XuesongBai
in reply to: adsk_loren
Yes, as Loren mentioned. Now the hotfix has been relaeased. You can get it at http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=15639656#section1
-Xuesong
Please mark as a solution if somehow I got it right.
Message 6 of 10
DarrenP
in reply to: XuesongBai
that hotfix worked
DarrenP
Message 7 of 10
DarrenP
another issue that came up that only affects factory design suite
http://forums.autodesk.com/t5/Autodesk-Navisworks/Everything-selected-when-opening-NW2014/td-p/43347...
has nothing to do with the service pack
DarrenP
Message 8 of 10
XuesongBai
Thank you for raising the issue. I have put the issue in our backlog.
-Xuesong
Message 9 of 10
dennis
Wouldn't it be nice if Autodesk at least put something in the SP install that would check for a FDS install and STOP the install before it breaks other programs.  Another example, AutoCAD SP2 if it "sees" Plant 3D, then DON'T install.  Instead, we have to break something, then try to figure out why and then start the uninstall process.
Message 10 of 10
tanghong77
in reply to: dennis
Hi Dennis, Thank you for the great suggestion and sorry for the inconvinience of uninstalling the package when found the breaks. NW SPs are intended to work on any Navisworks whereever it is from. However if there is similar break issue, we would consider the blcok of install to avoid inconvinience. Thanks, Irene
