Factory Design Utilities Forum
Welcome to Autodesk’s Factory Design Utilities Forums. Share your knowledge, ask questions, and explore popular Factory Design Utilities topics.
275 Views, 6 Replies
Margins
Is there a way to control the margin of 2D sketches that are automatically creating during the publishing of assets from Inventor?
6 REPLIES 6
XuesongBai
Hi there,
Could you tell me what is the problem you are encountering? I don't understand why you can want that.
-Xuesong
Please mark as a solution if somehow I got it right.
in reply to: XuesongBai
See the attached picture. The picture on the left is of the model. The picture on the right is the 2D asset that was automatically created during the asset publish process. Notice how the drawing has been cropped.
XuesongBai
Hi there,
 I guess you are publishing the Assembly as asset, right? So some parts in assembly are set as Reference in BOM.
Maybe you can change the Reference to Normal in BOM before you publish the asset.
-Xuesong
Yes, the assembly has some components that are set to reference. I was hoping that I won't have to change the BOM structure because then the BOM wouldn't be correct.
Any other ides?
XuesongBai
Hi there,
Absolutely. The other way is as below.
1,Open the DWG file that generated by publish.
2,Activate the sheet page by double click
3,Edit the view
4,In Mode State tab, you can change margin  to big enough value
But there is a potential issue. The position between 2D asset and 3D asset will not be matched when do sync2D/3D in Inventor.
-Xuesong
XuesongBai
Hi there,
I think another wokround to completely  fix the issue you encountered.
1,Open the assembly file before publish as asset
2,Change the Reference of parts in assembly to Normal temporarily in BOM
3,Publish the assembly as asset
4,Open the assembly asset in factory user library and change back  Normal to Reference of parts in BOM
-Xuesong
