Trying to make a simple asset. I drew it in ACAD and exported it to ACIS/SAT. It imported fine into Inventor. I went into Asset Builder, selected a landing surface and then went to publish it and I got this error (see attached). I've attached the SAT file itself because it's incredible that it can't generate a 2d plan view of this very simple part.
OK I tried a STEP file and it worked. Any idea why Inventor could read the ACIS file but not be able to generate the 2d drawing in the publishing step?
It also works for me.
It sounds like you will fail to create the base view in Inventor drawing.
Perpaps, we need to ask for Inventor team looking at the issue.
-Xuesong
