I'm using FDSU 2014 french and I have a problem when I do a "AutoCAD Synchronisation" in Inventor.
Works fine on english version.
Thanks for help?
Hi there,
I guess that you are using French Language Packs version which is installed in English version.Could you please create "Métrique" folder in "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates" and copy ANSI (mm).dwg and ANSI (mm).idw from "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Metric" to "C:\Users\Public\Documents\Autodesk\Inventor 2014\Templates\Métrique"?
-Xuesong
