http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22264351&linkID=15639656
Says my product cannot be found if I run it stand alone. If I try installing through AutoCAD Architecture is starts installing then backs out with a generic error.
Is this messed up or am I doing something wrong?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22420526&linkID=9240658
Also tried that one which is specific to Architecture with same result...
A problem prevented the Service Pack from being installed. Error code:1603
I am seeing the same issue. The service pack will not initialize even though I have the correct product.
hi there,
AutoCAD is separate installed. As default, AutoCAD will not be installed with FDS.You need to check the download of the AutoCAD installer in the panel when installing the FDS.
-Xuesong
I have similar problem. Maybe not related with Autocad but with FACTORY SP1.
I still have notice displaing forceing me to install the SP1 althought I did it before.
Since the forum has changed I did not have time to get familiar with new layout. I still don't know how to search in Factory forum, that's why I'm writing here. Sorry.
