Autodesk Factory Design Suite General Discussion
Valued Mentor
Logos_Atum
Message 1 of 13 (233 Views)
Connectorclasses
233 Views, 12 Replies
08-09-2012 02:07 AM
Hello there,
i have a question regarding the capabilities of connectorclasses.
Is it possible to add code to make the connectorclasses adapt colour styles of a text Parameter?
I made a multi value parameter of it and I am curios how to make connected assets change colour
dependent on the selection of the previous.
Is it possible to do this?
Thank you for your time
Daniel
- 2500K @ 4.2Ghz- 8GB - Radeon7970 -
- Xeon 1230V2 @ stock Ghz- 32GB - W7000-
- 2x Xeon 2670V2 - 64GB - W7000 -
- Factory Design Suite Premium Subscription-
Employee
jeff.pek
Message 2 of 13 (230 Views)
Re: Connectorclasses
08-09-2012 03:44 AM in reply to: Logos_Atum
Hi -- Thanks for your question.
Connector Classes don't support this directly -- they only propagate parameters from one component to another.
However, you could probably incorporate iLogic rules that apply other changes (such as color styles) based on those parameter values.
Jeff
Valued Mentor
Logos_Atum
Message 3 of 13 (228 Views)
08-09-2012 04:16 AM in reply to: jeff.pek
Hey Jeff,
okay  - iLogic, great this is possible anyway.
I got this rules included and running already.
The next step would be to link the logic in the assets in the Factory assembly right?
Is there an example of how it´s done available? I´m a ilogic newbie...
Thanks in advance
Daniel
Employee
jeff.pek
Message 4 of 13 (226 Views)
08-09-2012 04:23 AM in reply to: Logos_Atum
HI Daniel -
Not sure what you mean by that. Can you elaborate a bit?
Typically, in FDS, component parameters are pushed via the properties panel. This also collaborates with the FDS component instancing process to ensure that we create new copies of the assets when a new unique combination of key parameter values is created.
  Jeff
Valued Mentor
Logos_Atum
Message 5 of 13 (224 Views)
08-09-2012 04:41 AM in reply to: jeff.pek
Hello Jeff,
i truly tend to fail if i get into details.
But i´ll try...
I created assets with the following capabilities:
They communicate parameters via connectorpoints - height and width. Length is a key parameter too,
but i only defined it to accept user values.
I have rules defined for motorposition and colourstyles. All accesible on the Factory portion of Inventor too.
Now here is my question, is there a way to make the assets adapt the colourstyles of the first Asset i placed?
Can i define a rule in the assembly which makes the selected assets change colourstyle to the selection?
As it is important to keep the solution simple there is no other solution than a nice rule run via a form created with the assistant.
I hope this helps you
Kind regards
Daniel
Employee
jeff.pek
Message 6 of 13 (222 Views)
08-09-2012 04:53 AM in reply to: Logos_Atum
HI Daniel -
Thanks for the explanation.
I'm curious: Why is it that you want to make changes to the component colors?
It sounds like you're better off in applying assembly-level color style (overrides) instead of assigning the colors to the parts themselves. This would also be more effiicient, as a color change alone would not cause the creation of a new component.
I can't think of a way to do this automatically without writing some code (as an add-in). You can do this with an assembly-level iLogic rule semi-automatically, by create a rule that assigns a color style to all selected components when you press a button. This a special iLogic rule you create; this is described in the iLogic docs, I'm sure.
As far as I know, there's not a way to get a rule to run when a new component is added. This is something that you could do using an add-in.
Jeff
Employee
guosu
Message 7 of 13 (198 Views)
08-13-2012 08:34 PM in reply to: Logos_Atum
Hello Daniel,
Do you mean when two assets are connected,  change one asset color style, anthor asset will change color style together?
Sucy
Valued Mentor
Logos_Atum
Message 8 of 13 (194 Views)
08-14-2012 01:34 PM in reply to: guosu
Hello Sucy, yes exactly, is it possible? Any hint will do. Kind regards Daniel
Employee
XuesongBai
Message 9 of 13 (192 Views)
08-14-2012 06:08 PM in reply to: Logos_Atum
Hi Daniel Bro,
You can define the key (text) parameter in the connector class, which parameter in Inventor control the style. So once they are connected by connectors, the key (text) parameter will be propagated among the assets, afterwards, the style will updated also according to the parameter change.
-Xuesong
Employee
guosu
Message 10 of 13 (187 Views)
08-14-2012 08:06 PM in reply to: Logos_Atum
HI Daniel ,
You can define color as key parameter and use iLogic to realize color change for one asset. Then add this parameter color in connectorclass file. I have attached a sample asset. Hope it could help you.
Sucy
You are not logged in.
Ask the Community
